LED Sidemarker Bulb Question...PnP?
09-23-2012, 01:04 PM | #1 |
38
Rep 778
I am not very experienced when it comes to this stuff and dont want to mess up, so I recently ordered LED bulbs for my front turn signals and heard that if the sides are not led they will not match up. I ended up searching for replacement bulbs for the side markers and found these...http://www.e92-lighting.com/products/194_1A-91-0.html. I was wondering whether anyone else got these and if they are plug and play without any coding/resistors. Also will they throw any error codes? Thanks
09-23-2012, 01:36 PM | #3 |
Rep 175
you could buy any 194/t10 led and they won't throw errors for the side markers. They will, however flicker when you start the car. I would recommend the 5 5050 smd ones. You could find them in the vendor section
09-23-2012, 01:49 PM | #4 |
38
Rep 778
all of them will DEFINITELY flicker?
09-23-2012, 02:26 PM | #5 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
I believe flickering is just a side effect of the bulb check process that BMW performs. It's not a permanent effect. If you get errors, you can always get it coded out, too.
The i8 needs a V8 amirite?
09-23-2012, 06:00 PM | #7 |
Where'd my VTEC go?
481
Rep 6,067
They will flicker. Code out rear turn signal bulb check to eliminate the sidemarker flicker.
09-23-2012, 07:43 PM | #8 |
38
Rep 778
every time the car is turned on? thats not good news...
09-24-2012, 09:20 PM | #9 |
3441
Rep 79,211
The car does a bulb check, which send quick pulses to the lights. Only way to avoid them is to code them out.
I personally never found it to be a big deal, I had them on my car un-coded for 3+ years. I had the high performance bulbs side marker LED upgrade myself. They were error free. |
09-24-2012, 10:33 PM | #10 | |
Rep 31
I can attest to the HPB Sidemarker bulbs as well. Been running the ambers with no problems for the past few months.
