BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wash, Wax, Detailing and Cosmetic protection/repairs > Best Product to Remove This...
      09-21-2012, 09:31 PM   #1
toicy4ya
toicy4ya's Avatar
47
Drives: 06 BMW 330XI
Hello Everyone,
My wheels have what appears to be baked on brake dust/grime. Unfortunately the previous owner didnt came much about taking care of the wheels. Two months ago i tried utilizing some Mother's Mag & Aluminum Polish. It was able to remove a good amount of it, however it appears i constantly need to use Mothers to get the build up off. Is there anything on the market strong enough where i can spray it on and simply wash it off?
I Heard some good feedback about Sonax. Anyone have experience using it? Would it help my issue? Here are some pics as reference
Any feedback would be greatly appreciated.
2006 330XI BSM, Terra Cotta Leather Interior, ZSP, ZPP, ZWP, ZCV, Comfort Access, Adaptive Xenon, Steptronic, Logic 7, Nav w/ IDrive
      09-21-2012, 10:07 PM   #2
Bmwe90sg
Drives: Car
i know sonax is good. many detailers use it. not sure if it will help but give it a try. however once you get the rims clean, seal them with a rim sealer like nanolex rim sealant. that will help make washing easier and so that BMW brake dust doesn't bake on.
Goodluck
      09-21-2012, 11:16 PM   #3
blackrabbit
United Kingdom
78
Drives: 320d F30 M Sport
I used lighter fluid for spot cleaning tar and baked on dust. Works great on small areas
      09-22-2012, 04:50 AM   #4
toicy4ya
toicy4ya's Avatar
47
Goodluck
Have you used it? Is it true to its advertisement?
I always thought wheel sealants were a gimmick, does it really work?
Some of these bottles can be expensive. I'm sure many people have purchased an expensive cleaning product only to be thoroughly disappointed with the results and end up chucking the bottle in the trash can after its first use. It's happened to me several times. I don't mind paying the money as long as it does the job.
      09-22-2012, 06:26 AM   #5
Bmwe90sg
Drives: Car
i have used NANOLEX and I was very happy with results but to expensive use Chemical Guys Jetseal 109. thats stuff is GREAT and CHEAP. and its great for windscreen sealing, and 101 other things., i use that mostly and really happy with but first try cleaning with sonax.
      09-22-2012, 11:25 AM   #6
Pete Schweaty
Pete Schweaty's Avatar
39
Drives: 2014 750li
Simple green and a soft bristle tooth brush. Then apply a sealer or wax.
      09-22-2012, 05:36 PM   #7
mob17
mob17's Avatar
United Kingdom
400
Drives: E92 335D
Would IronX work?
      09-22-2012, 11:21 PM   #8
Bmwe90sg
Drives: Car
idk about iron x. and to the comment above saying to use aslant or wax. wax won't hold up, u will have to apply like every couple of days and its gets to hot. sealant will better but nopt like wheel sealant. use jet seal 109 like i said
      09-22-2012, 11:24 PM   #9
Bmwe90sg
Drives: Car
also try posting on autopia may be someone there knows more
      09-23-2012, 02:38 AM   #10
335isGuy
32
Drives: 2018 Bmw 340xi Msport
Toothbrush and sonax would work. Then a wheel sealant to help with the nasty break dust. I track my car and always apply wheel wax to my rims, makes it a breeze after.
      09-23-2012, 10:35 PM   #11
CJ421
CJ421's Avatar
1559
Drives: BMW M3
I use standard paint sealant on my wheels and haven't had an issue. I clean the wheels thoroughly (off the car) then apply Chemical Guys' EZ Creme Glaze and Blackfire Wet Diamond sealant. Very easy to clean wheels afterwards.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT
      09-24-2012, 01:37 AM   #12
psnt1ol
psnt1ol's Avatar
31
Drives: e90
There are stronger chemical wheel cleaner out there but they tend to be acid based and I generally stay clear from all of them.
I had the same issue on my wheel. I managed to resolve it by using the following.
2 applications of CarPro Trix (Iron & Tar Remover)
Meg D140 Wheel Brightener
Clay
Unfortunately, both Trix and D140 require some brush work so it is not a simple spray on/ spray off. Be warn.....both Iron X and Trix have a terrible smell and gloves are highly recommended when dealing with them. A well ventilated work area is a must.
After Claying, I applied 2 coats of BlackFire Metal sealant ( Paint Sealant works just as well but I have the Metal Sealant in my tool box so I used it). The sealant doesn't stop the brake dust from forming on your wheels but it does makes the wheels so much easier to clean. Now-a-days, I just knock them all off with water without the need of a wheel cleaner.
If you are serious about getting rid of all the nasty stuff on your wheel, I recommend you take the wheels off and clean them one at a time. It is actually much easier this way instead of bending over at some funny angle trying to get at them. This would also give you the perfect opportunity to clean the barrel.....while you are at it.
Good Luck.
What is absolute control???? Having the means and the abilities to exercise it at will but....chooses not to.
      09-24-2012, 10:47 AM   #13
1080eyes
Drives: 2011 328i vert.
I had a simular stain on my wheels. I used Stoners bug and tar remover. Just sprayed on a MF towel and it came off easy. I had also tried different cleaners and polishes.
      09-24-2012, 01:06 PM   #14
jiaan13
uʍop ǝpısdn
Drives: '11 335d, SG/Saddle, ZSP, ZPP
I used a Mr. Clean magic sponge on mine, and it worked great.
      09-25-2012, 02:56 AM   #15
toicy4ya
toicy4ya's Avatar
47
Holy shit, I had some Mr. Clean Magic Eraser that I generally use for my walls and tried it on the wheels. With a few light strokes I was able to get the caked on brake dust off easily. I didn't even have to force it in. I just need to follow up with some sealant. Unfortunately none of the sealants previously mentioned are sold at my local PepBoys.
      10-21-2012, 12:28 AM   #16
Phil325
Phil325's Avatar
Drives: 06 SGM E90
2006 325i  [10.00]
seriously??? I've had the magic eraser this whole time and I could've used it! will try tomorrow morning. thanks for the tip
work in progress..
      10-21-2012, 12:58 PM   #17
N8N
N8N's Avatar
Drives: 2009 E92 335i 6MT
My local BMW dealer sells Wheel Wax for not too much markup over retail. It seems to work well but I don't know if there is a better product or not out there. Like you I haven't seen anything marketed as a wheel sealer at any of my FLAPS. My wheels currently look better than those on 99% of the cars on the road now and after washing the car I literally take a MF towel and clean water and wipe the brake dust off the wheels. Been about a month since I applied, we will see how durable it is.
For remedial cleaning I have some Mercedes-Benz "metal dust remover" it is an oxalic acid based product, I don't think that you can buy it anywhere but maybe a DIY oxalic acid solution would work when I run out? I would not recommend this for regular cleaning but for old neglected wheels to bring them back to life it is magical. Brake dust just melts off, scrub with a soft brush and wash with dish soap afterwards, et voila nice clean wheels. I don't like to let my wheels get to the point where I have to use this stuff but I keep buying used cars and wheels and, well, you know.
      10-23-2012, 03:36 PM   #18
Gig103
Drives: 2014 Tesla P85D
Awesome advice, because I have a bottle gathering dust. I switched to Blackfire Wet Diamond for the paint and it's too expensive to put on rims. I'll try the Jetseal
Was: 2008 335xi sedan 6MT Black Sapphire Metallic
Is: 2014 Tesla P85D (Blue Metallic)
Wife's: 2013 Infiniti G37 S sedan 6MT, Black
      10-23-2012, 04:04 PM   #19
mob17
mob17's Avatar
United Kingdom
400
Drives: E92 335D
Originally Posted by mob17 View Post
Would IronX work?
Tried this and yes it does. Not too sure if other products would work better/quicker, but this worked very well.
      10-24-2012, 01:22 PM   #20
UncleWede
UncleWede's Avatar
Drives: G01 X3 M40i Dark Graphite
Be careful with those Mr. Clean, they will scratch your wheels. Not that it's as visible as on your hood, but . . .
Pull the wheels, put on a board between sawhorses, then clean, clay, and seal. I prefer Poor Boys Wheel wax. I've managed over the years to use almost 1 tub by applying 2-3 coats twice a year, both inside and out.
      10-24-2012, 06:20 PM   #21
ScheerSpeed
ScheerSpeed's Avatar
Drives: '13 F30 Estoril M-Sport 335i
Clean them well with SONAX Full Effect, Clay, Swissvax Cleaner Fluid Medium and seal it with Swissvax Autobahn after and you should be good!
      10-26-2012, 07:52 AM   #22
2QAYL
Drives: None yet
Mr. Clean magic erasers should never be used on your vehicle unless you really want to damage it, or you have the materials and training to correct the damage that may occur.
For wheel cleaning, I use Hydroflouric Acid (HF). It will get everything off and not damage the wheel if cone properly. A lot of people don't like using it b/c of the dangers associated with it but it really does the best job in a short period of time.
Make sure to wax your wheels with a carnuba wax after thoroughly rinsing and you should be good. Just make sure you keep up on keeping them clean!
