ZPOST
  TireRack
      07-27-2007, 10:00 AM   #1
duong
Drives: BMW Z4
Can I install HIDS on my Projectors headlights?
Can I buy an after market ballast for my z4 halogen headlights? Will it work well?
has any of you guys done this?
thanks
      07-28-2007, 02:08 AM   #2
em2b96p
15
Drives: cbr600rr
you cannot simply purchase a ballast and use it with your existing halogen headlights.
you need to purchase a complete HID kit with bulb and ballast
      07-29-2007, 09:47 AM   #3
duong
Drives: BMW Z4
I apologize, thats what i meant. I want to purchase a full kit and bring it to a garage and get it installed.
something like
http://www.shophid.com/images/PromaxKit.jpg
      07-29-2007, 02:19 PM   #4
BimmerZealot
61
Drives: 2019 BMW X3 xDrive30i
Yes that will work, you may need a re-flash for HIDs at the dealer, it was required for the E46 not sure with the E85
      07-29-2007, 11:21 PM   #5
duong
Drives: BMW Z4
oh ok. Thanks but what does the re-flash do? would it matter if i didnt bring it to BMW for em to re-flash?
      07-29-2007, 11:40 PM   #6
pbdm4k
pbdm4k's Avatar
74
Drives: 2010 335d
MTEC HID kit from Ebay.
Installed, working, and proven! No reflash or any other messy stuff necessary.
Plug and play!
      07-30-2007, 02:11 AM   #7
BimmerZealot
61
Well the reason for the reflash is HIDs pull a different amount of current then halogen bulbs both on startup and under normal operation. So for SOME cars you will get a bulb out warning telling you that your headlights are out even if your HIDs are working. The reflash will tell the computer it now has HIDs and to check for the amount of current the HIDs pull instead of the halogens. Without a reflash you may have a bulb out warning, which can cause fast blinking, flickering, etc. However you can get the kit first and see if you get a bulb out warning, if not then nothing to worry about.
      07-30-2007, 08:19 AM   #8
pbdm4k
pbdm4k's Avatar
74
Drives: 2010 335d
Just need to look for what kid you buy out there, some kits (such as the MTEC one) are made in such a way that they draw the same amount of power as your halogens would so as not to throw off the ecu and give you a bulb out warning.
Cheaper HID's would most likely cause a bulb out warning. May also be messier to wire as ignitors are seperate from the ballasts, so more stuff to mount. Nicer kits have the ignitors integrated into the ballasts to save space.
      07-30-2007, 11:51 PM   #9
BimmerZealot
61
That is 100% not true, all HID kits draw the same amount of power and that is 35W constant and +/- on startup usually more. Unless it is a 50W (brighter) kit they will all pull the same amount. Generally low beam halogens pull 55W and high beam halogens are 100W (brighter, on less). Also it does not matter whether the igniter is inline or built into the ballast they still all pull the same amount of power. I work at a wholesale importer of HID kits on the West Coast so I know all about them.
All the misleading that is thrown into eBay and other online kits is just to sell more kits, essentially they are all the same ballast/bulbs just with each companies sticker on it. Of course not all factories make their ballast/bulbs the same so there is a quality issue. Personally our ballast/bulbs have a very low failure rate.
Long story short, all HID kits are the same when it comes to power regardless of how they are wired, how they are designed. Quality and longevity are a different case. Whether or not a car has compatibility issues with an HID retrofit is car to car specific. An example being Mercedes Benz we've had numerous problems with MB cars rejection HID kits but most can be fixed with a wiring harness which pulls direct power from the battery or inline capacitors and diodes.
      08-01-2007, 10:27 AM   #10
duong
Drives: BMW Z4
Thanks!
would our cars be H8 or H7?
      08-01-2007, 10:40 AM   #11
pbdm4k
pbdm4k's Avatar
74
Drives: 2010 335d
H7
      08-23-2007, 10:16 AM   #12
BlackSapphireZ
97
Drives: 22 GLE 53 Coupe
i bought a cheap kit and didn't require a reflash
      09-24-2007, 11:58 PM   #13
yonimation
8
Drives: 07 z4
anyone bought a cheaper set of hids other than mtec that dosnt require a reflash? post link plzzz thanks!
      09-25-2007, 02:06 AM   #14
mister_roger
mister_roger's Avatar
13
Drives: 2003 Maldives Blue 2.5i
Where does one mount the ballast box when installing one of these aftermarket kits? I'm contemplating an HID conversion some time in the next few months and would definitly like to hear some installation stories.
2003 Maldives Blue 2.5i -- 18" M6 wheels, 12mm rear spacer, ///MZ4 front bumper conversion, Eibach lowering springs, Koni shocks, Hotchkis F/R anti-roll bars, Helene Performance air filter.
      11-05-2007, 12:54 PM   #15
pbdm4k
pbdm4k's Avatar
74
Drives: 2010 335d
Some people have atteched them to the back of the fender well covers, mine are currently double sided taped to the inside of the engine bay, however future relocation, i will remove the bumper and mount them either behind or below the rebar.
      11-20-2007, 11:17 AM   #16
Hawkeye
Hawkeye's Avatar
2070
Drives: '07 Z4 Coupe, '21 X3, '16 GMC
Speaking of this, BimmerZealot, you said you have a HId kit for your fogs as well, or are they just different bulbs?
2007 Z4 3.0si Coupe • 6 MT • Black Saphire Metallic • PP • SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4
2017 Harley StreetGlide • Denim Black • V&H Tune
2021 BMW x30i • Phytonic Blue Metallic • Fully loaded
      11-20-2007, 05:15 PM   #17
BimmerZealot
61
I do have an HID Kit in my fogs, the fogs are H11 bulbs, whereas the halogen low beams are i think H7 bulbs. You'd need a whole separate kit (pair of H11 bulbs & pair of ballast) to install HID fogs
      11-21-2007, 11:30 AM   #18
Hawkeye
Hawkeye's Avatar
2070
About how much would a setup like that run if I install it myself? They do look nice
      11-21-2007, 12:02 PM   #19
BimmerZealot
61
For the HID Fogs? Depends where you get them but I'd say an average of about 150$ for a pair of HID bulbs with the base of your choice and a pair of ballast. Of course there are the extremes of super cheap eBay kits and overpriced hyped up kits.
      11-26-2007, 12:49 AM   #20
BMW^Z4
BMW^Z4's Avatar
Drives:
Can I install HID withour remove front bumber? I want to just remove the front wheels and work from the back side of the lights ...
Sterling grey ,108 starspoke, alarm,KW v3 suspension,clear lights,cd/mp3, ipod 20GB, hardtop,manual,wind deflector, aerodynamic package, silver trim,Michelin pilot sport tyres, cruise control etc ...http://www.freewebs.com/knb921/
      11-26-2007, 01:00 AM   #21
BimmerZealot
61
Yes you can, after removing your front wheel, unscrew the two quarter screws on the upper panel and that will give you access to the back of your headlights. That should give plenty of access for the install.
      11-27-2007, 10:12 AM   #22
jefflazo
7
Drives: Mini Countryman
Oh man you guys are gonna make me spend more money! At some point I think I am going to install the factory fogs, then an HID upgrade now...
Is there wiring harness there even if I didn't have them originally installed? I also assume that I have to cut out the holes in the bumper as well.
zpost
