Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Tire Mounting Tool
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      07-26-2007, 05:44 PM   #1
bg
Drives: BMW X3
Tire Mounting Tool
I read somewhere that BMW markets a simple tool that helps lift the tire off the ground and helps align the holes so that the lugs can be easily screwed in.
I always seem to strain myself in the process. Tried the search function with no luck. Can anyone help? Thanks in advance.
      07-26-2007, 08:17 PM   #2
montreal_bimmer
OEMconcept
montreal_bimmer's Avatar
Italy
174
Drives: BMW
2006 325i  [10.00]
never heard of it.... but if you find it, let us know what it looks like...
      07-27-2007, 10:24 AM   #3
dmichael
Drives: 2011 GTI
I had this with a M-B c230k. It's called a guide pin. Threaded on one end so you screw it into the uppermost lug hole, since its about 4 inches long, you then slide the wheel hole onto this pin and all the other holes line up. I used it all the time, made changing wheels so much easier. Not sure if the M-B version, which I still have will have the same thread size as BMW, doubt it.
LeatherZ sells this pin for BMW/MINI. http://leatherz.com/Merchant2/mercha...gory_Code=Mini
2008 E90 328i - Sparkling Graphite/Terra/Dark Burl, 6MT, Sport, Premuim, Fold-down seats, iPod/USB(6FL). M-Sport Steering Wheel, ZHP M-Sport Shift knob, Euro fog lights. Euro Split Armrest
      07-27-2007, 04:08 PM   #4
jc777
jc777's Avatar
Drives: E90 325i 2006
http://www.bmw325i.net/wheel_pin.shtml
      07-28-2007, 08:47 AM   #5
Wissam
20
Drives: 2007 e90 328I
Just go to your local hardware store and purchase an M12 bolt, 1.5mm thread pitch (not 1.8), and chop the head off...cheap and simple...
      07-29-2007, 06:11 AM   #6
ENINTY
173
Drives: 2006 325i Sport
The tool you are talking about used to come in every BMW tool kit until the run flats came into use. All it is is a 10" round steel bar, plated (so it won't rust), with a grey plastic end piece that slides into the bolt hole on the hub. I helps line up the wheel bolt holes to the threaded hole in the hub. Any good dealer should get it for you, it's under $10. Or go to a junk yard.
      09-19-2007, 08:26 PM   #7
TurboFan
Ski bum
TurboFan's Avatar
317
Drives: sideways
Call Andy at LeatherZ. I'd never seen one before, he gave me one this evening. Works like a charm.
1999 e46 328i Ti Silver / Black[retired]
2007 e90 335xi Jet Black / Black[retired]
2011 e70 X5 35d Vermillion Red / Cinnamon
2011 e92 M3 LeMans / Fox Red extended
