2007 CCC professional nav with screen £425 collected
09-17-2012, 12:05 PM | #1 |
10
Rep 235
Comes with nav unit, screen and facia plate.
Also comes with 2007 nav disc and a 2011 backup All works fine no need for coding either...well not in my 2005 e90. £425 collected or £450 posted |
09-17-2012, 01:56 PM | #2 | |
13
Rep 205
Thanks. |
09-17-2012, 02:15 PM | #3 |
10
Rep 235
No controller or cable as I just used the ones fitted in the car to my business nav.
Unit has the buttons on it and the facia is to fit. Ill get pics up tomorrow..but its a standard pro nav unit from a 2007 car.. |
09-18-2012, 04:11 AM | #5 |
13
Rep 205
Hi there,
I am interested but the last CCC system on here sold for much less & that came with screen cable & I-drive controller. Any chance of a price correction? |
09-18-2012, 04:42 AM | #7 | |
13
Rep 205
I was under the impression that the pro system needed a different monitor cable between the screen & unit over the business system & they also have different heat pipe thingy's on the rear. Did you just unplug your business system & install this & it worked? Thanks. |
09-18-2012, 05:04 AM | #8 |
10
Rep 235
Silver knob controller usually go for peanuts..later controller wont work
Cable needed slkght mod at the screen end, just needed a bit of plastic trimming off. Its all plug and play...i didnt do the heat tube a d it was in the car for 3 years and no probs |
09-18-2012, 05:18 AM | #9 | |
13
Rep 205
Just read about trimming the plastic lug off the end of the cable so that should be ok. So for you the unit never got too hot when using for extended periods? I suppose I could run with this & change it if it was a problem. I am currently watching some on ebay so I will have a think about the price. Thanks. |
09-18-2012, 06:29 AM | #11 | |
195
Rep 2,100
But your firmware needs an update to enable the new 7 button cic controllers to work. HTH |
09-18-2012, 06:40 AM | #12 |
10
Rep 235
Thanks for clarifying that..
Oh and the one sold cheaper on hear was the older version... This has the staion setting buttons and looks much better in my opinion |
10-04-2012, 01:25 AM | #17 |
10
Rep 235
It takws 15 mins tops the 1st time..as u need to trim a lug of the connector..
After that it can be done in. 5 mins.. Its so much nicer than the business nav... |
10-04-2012, 05:15 AM | #18 |
Rep 78
Is there no need for a software update or such like?
I think I have the M-ASK system. http://en.wikipedia.org/wiki/IDrive |
