Review: ModMy3 Cree LED Angel Eyes
09-14-2012, 08:48 PM | #1 |
Rep 20
Today I got a chance to install the Cree LED Angel Eyes from modmy3. These are for my pre-LCI with factory xenon. The install is the same as most halos, however, these come with a resistor that DOES NOT fit in the housing. I was instructed to leave the housing off (no, it is sealed for a reason), or drill a small hole. I bit the bullet, drilled a hole, and taped the resistor to the exterior of the housing. I filled the gap with Marine 5200 (won't leak). These are very bright. I uploaded a day time pic so you can see the difference. Even with my 8mp camera phone you can tell the difference. I would have liked a self contained unit that didn't have any external part, but at $100 vs $160 Ill give it a shot. Overall I am very happy with the light output, seeing how I am going to be coding these as DRLs. Night and day to the stock halogen, which I thought looked awful yellow. Onto the photos-
Bulb housing- Bulb housing and resistor Bulb Installed - Hole drilled in housing, wires connected to test (before epoxy) Connectors that go in trash- Cree Right, Stock left in daylight-
2007 Barberahellrot 328i Xenon . Nav . Coded
New to E90, seasoned E46 (adenosinebambam on E46fanatics) Last edited by Barberra3er; 09-14-2012 at 08:57 PM.. |
01-13-2013, 01:09 AM | #2 |
Rep 43
Thanks for this review, I was looking at these but now that I see the issue with the resistor I have changed my mind. You saved me some disappointment.
02-01-2013, 07:19 AM | #3 |
7
Rep 45
I was able to tuck the resistor in the compartment where the wires came out of. The resistor fit snugly in that upper compartment and I ran the wires through the same hole back into the AE compartment. I bought a different brand, but they look Identical.
