Low tire light
09-12-2012, 09:51 AM | #1 |
12
Rep 166
Drives: 2007 E92 335i 6MT
Low tire light
I got a low tire light on my 335i yesterday. I tried resetting it but it didnt go away. I checked the tire pressure and its fine. Does anyone know what the problem could be?
E92 335i // Space Grey on Coral Red // Muffler Delete // Blackline Trim // BMS DCI // JB4 // VRSF 7'' Intercooler // H&R Sport springs // Matte Grill // Michelin Pilot Super Sports
09-12-2012, 09:52 AM | #3 |
12
Rep 166
what do the tpms cost to replace?
09-12-2012, 09:53 AM | #4 |
52
Rep 748
Did you drive on it after resetting it?
2008 335I E92, AW, VFF700, 18" Forgestar F14, M3 front/side, M-tech rear, AMS IC, H&R Touring Cup Kit suspension, HID AE, ER Charge Pipe & Synapse BOV, CIC Retrofit, Quafie, DSS, Defiv Lockdown, SPEC 2+/Steel SMFW, Walbro 450
09-12-2012, 09:55 AM | #5 |
32
Rep 520
When you hit reset did it show a check mark? you may not have completed the process
KW V3's / AA Stage 2 Supercharger / Catless Mid-pipes / AA Mufflers / Apex Arc-8's / PFC 09's |
09-12-2012, 09:56 AM | #6 |
Rep 39
Most likely a bad sensor or possibly a programming issue. I don't know how in depth your knowledge of the TPMS system is but I will explain as much as possible. Each tire and wheel has it's own sensor inside. Each sensor is an electronic device and therefore needs a battery. These batteries are non-serviceable as they are sealed within the sensor. Here at our facility we do start to see sensors dropping out due to low battery power around 5-6 years. Although we do see ones go much longer this is our experience. This is not to say you do not have another fault in the tpms system but it is certainly a possibility.
Does the light flash at all or always stay solid? The answer to this question should tell more of the story. |
09-12-2012, 09:56 AM | #7 |
12
Rep 166
yeah it did show a check mark and i did drive for a while afterwards. Still did not reset. e90328 said it might be a bad tpms. what do those cost to replace?
09-12-2012, 09:57 AM | #8 | |
12
Rep 166
09-12-2012, 09:59 AM | #9 |
Rep 39
You can usually find them aftermarket for about $75 - $100. You would then need it installed but any garage that does tires can do that. If you get the right sensor it should be able to learn to your tpms system without a trip to BMW.
09-12-2012, 10:00 AM | #10 |
Rep 39
09-12-2012, 10:01 AM | #11 |
12
Rep 166
i would prefer anything over going to BMW lol. know anywhere that i can get them?
09-12-2012, 10:03 AM | #12 |
Rep 39
Haha didn't think about this at first but your first issue will be finding which one has gone bad if this is in fact the case. Some larger garages or big tire shops can diagnose TPMS issues with going to BMW. Obviously BMW can take care of this for you but expect a diagnostic fee and then dealer pricing on a sensor.
09-12-2012, 10:04 AM | #13 | |
Rep 39
You will find it under the wheel/tire drop down |
09-12-2012, 11:03 AM | #14 |
28
Rep 457
I've replaced 2 cause of bad batteries. It happens. Any tire shop can install. First one just failed. Second one was like dying and would be good for an hour then trip the error then good then trip the error. Was annoying as hell. Idrive goes bonkers
09-12-2012, 11:35 AM | #15 |
Rep 39
Do you remember how much you paid per sensor all said and done?
09-12-2012, 11:35 AM | #16 | |
DIYER
614
Rep 5,521
Ask for Joey, some of the best customer service I have ever had....I am getting my rims from him: http://preferredcustoms.com/
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
09-12-2012, 03:22 PM | #17 | |
12
Rep 166
09-12-2012, 03:23 PM | #18 | |
12
Rep 166
09-12-2012, 07:56 PM | #20 |
69
Rep 868
I bought 2 on eBay for $45 each
Whereever u get make you get compatible make for the year of ur car
JB4 G5 ISO , AR DP's, DO Meth kit Trunk Mount, ETS 5" Intercooler, M6 Rims, ER Charge Pipe, Fordged DV's, MMp relocated inlets, Ebay 4" chrome Tips, Lux Angel Eyes **********11.910 @ 117.09***1.851 60'********** |
09-12-2012, 09:56 PM | #21 | |
10
Rep 28
About the low light, if your sure you reset the system correctly and have the correct pressure, the battery is probably shot. Find a shop that utilizes a Bartec tool and they can pull up all the info on the sensor. Varies by year but they can pull temperature in the tire along with air pressure and what not. If the Bartec cant wake up the sensor and pull the info, the sensor is shot. |
09-12-2012, 11:43 PM | #22 | |
12
Rep 166
