M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > F10 M5 DIY Guides
      09-10-2012, 07:30 PM   #1
IND-Distribution
BMW obsessed
IND-Distribution's Avatar
9575
Drives: G82 M4 / G87 M2
IND Trunk Badge Installation Procedure
In continuation of supplanting the BMW chrome accents, one of the other areas require attention is the trunk badge. BMW always supplies a chrome badge denoting the given vehicles model. Although we will not substitute the infamous Texaco Red and Bavaria Blue accents, we will provide enthusiasts with a badge suitable for the theme of their vehicle.
Similar to our gloss black side marker we utilize the OEM piece as a base.
Tools required:
  • Painters Tape
  • Bondo spreader
  • All purpose cleaner
  • 3M adhesive promoter (Optional)
1.) The first and very important step is to mark the location of the factory trunk badge. This is accomplished by framing the current chrome trunk badge with the painters tape. The painters tape will provide you with a outline of the badge for reinstallation. As you can see in the photo our technician also indicates the letter position with a simple pen mark.
2.) Simply take the bondo spreader and gently work your way through the 3M adhesive backing. The more patience demonstrated in this step will result in a easier clean up.
3.) When the chrome badge is removed from the vehicle there may be some adhesive left over from the backing. Simply remove this adhesive with a all purpose cleaner carefully applied it to a microfiber.
4.) Now that the surface is clean feel free to apply a little adhesive promoter. Alternatively, at this time you can simply apply the gloss black lettering. Remove the wax paper cover on the adhesive of the badge and apply one letter at a time with light pressure.
5.) Upon completion remove the painters tape, clean up the area around the badge, and admire how the removal of a little chrome piece can change the back of a vehicle
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
      09-12-2012, 10:20 AM   #2
chudak18
chudak18's Avatar
Drives: E92 335, W463 G55
Nice. Can't wait to do this! .... Stupid chrome lol
      10-02-2012, 10:24 PM   #3
Rob@StrasseWheels
Rob@StrasseWheels's Avatar
458
Drives: 2023 BMW G80 M3 Comp
PM me a price for a set of these but for my M3!
@Strasse_Robert | (786)701-3649 | Robert@StrasseWheels.com | www.StrasseWheels.com
      11-26-2012, 10:10 PM   #4
Grayblack
Grayblack's Avatar
182
Drives: E92 M3 and G07 X7
I did mine today. It helps to blow dry the old badge before removal. It softens up the adhesive.
      11-27-2012, 02:45 PM   #5
IND-Distribution
BMW obsessed
9575
Post a photo
      11-27-2012, 05:12 PM   #6
Grayblack
Grayblack's Avatar
182
Here's the finished product. Thanks IND!
      01-04-2013, 05:56 PM   #7
vaibhav11
vaibhav11's Avatar
Drives: 2016 F10 M5 PMS Limited Editio
I put the gloss black emblem from IND on my Monte Carlo Blue M5. The installation was pretty easy... I just followed the instructions posted by IND.
I'm somewhat indifferent on the black emblem on the MCB color. I like that it matches the black side marker grills that i put in, as well as the black kidney grills. But it's also hard to read the M on the MCB color. It could have been the lighting this afternoon when the did the install, and the car was pretty dirty too. I'm sure I'll get used to it.
Cheers.
      01-04-2013, 08:45 PM   #8
nybimmerfan
nybimmerfan's Avatar
Drives: 6-Spd Manual MCB M5
Cheers.
I too have a monte carlo blue M5 and contemplated on changing the chrome highlights of the car (front and side grills and M5 badge) with the black ones, however, after seeing in person a friend's M5 that had those accents changed from chrome to black, I decided not to proceed. I did not like it at all as it seems that chrome gave the monte carlo blue body much more stature and elegance. The black accent would probably go better in a lighter colored body such as white but not on a dark body such as MCB. Anyway, to each his own and hope those changes grow on you soon.
      01-05-2013, 08:21 AM   #9
stealth.pilot
Knight Commander
stealth.pilot's Avatar
United Kingdom
559
Drives: 2014 911 Turbo S
Cheers.
Yes you lost contrast. I wouldn't change accents on an MCB car. Black doesn't work unless you want the feature to be invisible. The same is true of the grilles. They are deemphasized in Black on Blue.
It's counterintuitive but when you apply black accents to MCB you are doing the opposite of what others do when they apply black accents to white or silver cars. They are creating contrast and we would be destroying contrast.
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450
Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray
      01-31-2013, 08:02 AM   #10
Protious
30
Drives: 2013 BMW M5
Just finished my install last night, makes a HUGE difference on AW!
      02-25-2013, 07:05 PM   #11
84H
Newbie: quick learner
84H's Avatar
United Kingdom
Drives: M5 Performance Edition
Tidy...
2010 Land Rover Discovery HSE in white
2008 Techart 997 Turbo Cab- 650bhp in black
2009 Yamaha R1 in black and gold
      02-25-2013, 07:38 PM   #12
py0413
py0413's Avatar
110
Drives: Slow
Cheers.
I have a MCB too and after a little experiment with plasti dip the "M5" emblem to glossy black, I ripped it off and thought it would probably be better not to have them blackened. I really don't like those chrome so I will try frozen silver or even brushed aluminum finish when I have time.
Nate, I wonder how frozen silverstone
pieces will look on MCB because it is a bit blue-ish, isn't it? Might be a good match?
Must stop eating..............
      06-10-2013, 02:52 PM   #13
mwlmd
mwlmd's Avatar
Drives: Porsche 991 TTS
Those of you who have done this. Did you use adhesive promoter? Is it necessary? I am note sure where to get it. If it isn't needed I am happy to proceed without it.
Thoughts?
CURRENT:
His: Porsche 991 Turbo S
Carrera white/Black
Hers: BMW X3MC
BSM/Black
      06-10-2013, 03:47 PM   #14
vaibhav11
vaibhav11's Avatar
Thoughts?
I didn't use an adhesive promoter. I cleaned the area pretty good with a soft cloth and some windex glass cleaner. The new emblem went on pretty easily.
* 2021 BMW X7 M50i
* 2016 BMW F10 M5 Pure Metal Silver Limited Edition
* 2008 Lexus GX470
* 2000 Acura NSX-T
      06-10-2013, 06:05 PM   #15
mwlmd
mwlmd's Avatar
Good to know! I will proceed without it. Thanks for the reply.
CURRENT:
Carrera white/Black
Hers: BMW X3MC
BSM/Black
      06-29-2013, 01:15 PM   #16
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
24981
Drives: '22 Chalk Gray Porsche C2S
Looks so good on Alpine White.
      12-01-2013, 01:01 PM   #17
Mikeisen
Civilian
Mikeisen's Avatar
13
Drives: 2016 Mineral Grey M4 F82
2016 BMW M4  [0.00]
That's the look most of us are looking for. Just did the install today, and it looks awesome. Will post some pics soon.
2016 F82 M4 - Mineral Grey
2009 911 Turbo - White
      12-01-2013, 01:05 PM   #18
stealth.pilot
Knight Commander
United Kingdom
559
I don't know. The other thing I find is that painted badges and trim look cheap. If you're going to do this order the factory black chrome versions through IND. Those give you a much more polished factory appearance.
      12-01-2013, 09:37 PM   #19
Mikeisen
Civilian
Mikeisen's Avatar
13
2016 BMW M4  [0.00]
Lol, just ordered the side vents and rear badge through iND tonight, but all this stuff is plastic. Even the original "chrome" trim from BMW. Will definitely get some pics posted when done.
      01-22-2014, 04:04 AM   #20
Bluehorseshoe
Bluehorseshoe's Avatar
305
Drives: M5 CS
Contrast is great if that's the look you're seeking, sure looks beautiful and appropriate on the AW.
But if going for a more subdued look, I think it would look nice on darker colors as well.
At least this is what I'm hoping for as I just ordered for new black M5.
      01-22-2014, 06:35 AM   #21
GOLFFRR
GOLFFRR's Avatar
10797
Drives: GOLFFRR cart
sweet, can't wait to get one that says "M4"
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST!
Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101
vipfinance@bmwofcamarillo.com for warranties!
      04-29-2014, 10:47 PM   #22
cassidysdad
Drives: 2014 M5 gone, 2016 pms m5
nate
easy install
thanks
j
