Boost safety fix?
09-08-2012, 04:47 PM | #2 |
161
Rep 7,377
I suppose you have jb4 on map 5? If yes just up the safety to 18 and log to see all is good.
09-08-2012, 09:31 PM | #3 |
227
Rep 658
Is there anything wrong with setting the over boost safety at something high? Let's say at like 20? Over boost is not targeted boost so I'm not sure how it would be harmful.
09-09-2012, 04:30 AM | #4 |
161
Rep 7,377
The jb4 G4 map 5 autotuning is capped to 17 psi so up max boost to 18 to fix.
09-09-2012, 09:09 AM | #5 | |
Rainbow Racer
1008
Rep 2,539
You have to be more careful with the G5 board. If I set my overboost to 20psi, it'll hit 19.7psi (with meth) despite only having a meth additive to 50 (which in theory is supposed to cap out at 17.5psi). If I set it to 18.0, it'll target and hit 17.5psi consistently.
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 Last edited by spool twice; 09-09-2012 at 09:15 AM.. |
09-09-2012, 09:14 AM | #6 | |
Rainbow Racer
1008
Rep 2,539
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
09-09-2012, 05:57 PM | #7 | |
539
Rep 1,463
I guess I have to turn off the open fuel auto looping and start setting it down increments of 5 until the CELs go away. First run, really good, with a CEL 3/4 towards the end, cut off power and let me still use stock boost, but ran a 12.21. Tune only on stock Kumho SPT tires. The rest. LIMP modes. I was pulling 7.8-7.9 1/8 miles at 91.xx mph, and then LIMP mode and cross the 1/4 mile line at 12.6-7 at 94mph. |
09-09-2012, 06:38 PM | #8 |
Rainbow Racer
1008
Rep 2,539
that's seriously quick for just a tune! Good times, despite the hiccups.
-Loe P.-
09-09-2012, 07:28 PM | #9 | |
227
Rep 658
I think its the post shift spikes I've been getting that may be getting up to around 20psi. |
09-09-2012, 07:30 PM | #10 |
Rainbow Racer
1008
Rep 2,539
it's possible, but post-shift spikes normally don't last a second, unless my logs are different from your's
-Loe P.-
