Angle Eye Fiber Optics
09-08-2012, 10:05 AM | #1 |
36
Rep 1,054
I have a set of angle eyes on driver side that burnt out from the bulb. They are black, sooty, melted and do not transfer light to the halos. I was hoping to take the halos out of another headlight and replace them however they are not easy to reach. I took my car to a shop to have them open the headlight and they are saying that the halos from a passanger side headlight will not work for the driver side headlight. I have an old passanger side headlight but the driver side was all busted up. I was thinking the the outer halo on one light could become the outer halo on another but the shop is telling me that the driver side halos are different than the passanger side halos. This just doen't make sense to me and I have tried to explain that I understand that you can't use the right halo on one side and have it be the right on the other side, you have to use them like this.... inner halo= inner halo, outer halo=outer halo but I can't seem to get them to understand this concept. There are no part #s on these pieces as they are enclosed in the headlight so I can't compair part #s. Can anyone confirm that the halo pieces different for the driver side headlight than they are for the passanger side headlight?
o O O o
JB4 beta 15 ohms FSB,AEM inline filter/ CM 10, ETS fmic, ER custom made charge pipe,TSW Donnington 18's,Simitumo HTRZ3, Injen DCI, AR DPs, Forge DVs, AA SLD, Koni FSD, ZSP springs.
09-08-2012, 10:10 AM | #2 |
194
Rep 6,136
Pretty sure they are slightly different on the E90 Pre-LCI, the outer fiber optic may be a little longer. If I were you, if you are going through that trouble to open the headlights, I would just buy some full LED replacement rings and call it a day.
09-08-2012, 10:48 AM | #3 |
141
Rep 2,217
The shop is right.
The halo's 'fiber optics' (as u call it) can't fit from one side's headlight to the other. The bottom of the rings have an entry point [tube] to the headlight that is bent towards the back of the headlight housing; both rings doing this making them able to both be lit up by one single bulb. The opposite curvature is applied to the other side, which is why this can't work. |
09-18-2012, 04:36 PM | #4 |
36
Rep 1,054
thats what I needed to know!!!! thanks! I need optics from another driver side headlight. Can anyone help me find these parts.
09-19-2012, 02:22 PM | #5 |
101
Rep 265
