Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > A seafoam side effect?
      09-08-2012, 02:15 AM   #1
clairvoyant
clairvoyant's Avatar
79
Drives: Bavarian Manure Wagon (BMW)
2007 335i  [5.24]
Question A seafoam side effect?
Since I did the seafoam treatment two days ago, I notice my engine oil temperature runs slightly hotter than usual temperature (a half and three notches on the oil temperature gage). Is this normal (and it will go away after time) or am I looking at different potential problems?
The car has approximately 60000 miles. I did the seafoam treatment every 20000 miles.
Thank you for your help in advance, folks.
      09-08-2012, 02:41 AM   #2
Beemw335
62
Drives: 335i
Did you put any seafoam in the oil?
Some recomend to do that and then change it right away.
If not, its not related.
      09-08-2012, 07:36 AM   #3
clairvoyant
79
2007 335i  [5.24]
I did the seafoam via the vacuum line, the good old fashion, then thick white smoke and so on.
Now I worry about the water pump.
      09-08-2012, 10:20 AM   #4
ksalih
ksalih's Avatar
Drives: 2018 M2 LCI
Seafoam through the vac lines or the throttle body won't clean the carbon if that's what you were hoping for. the n54 is direct injected, being so, the seafoam will never even see the carbon. Seafoam was great for my Jeep, i swore by it, unfortunately in our cars through the vac lines or throttle body it doesn't see the carbon build up.
'2018 F87 M2 LCI | LBB | GC Camber Plates | Ohlins R&T 90/190N/mm | 18x10 et33 square 275/35 | MPe | Poly Transmission Mounts | Recaro Sportster CS
      09-08-2012, 10:26 AM   #5
Fully_Bolted
11
Drives: E92 335i
Lol it will see the carbon, although the effectiveness is questioned. Its when you put seafoam in the fuel tank that it will never see the intake valves. Through the throttle body or vacuum line is the only proper way to do it on the N54.
      09-08-2012, 10:28 AM   #6
ksalih
ksalih's Avatar
Drives: 2018 M2 LCI
Seafoam will see the carbon buildup in our intake valves? Please explain, excuse my misunderstanding if this is the case.
      09-08-2012, 10:32 AM   #7
Fully_Bolted
11
Drives: E92 335i
Since our engines are direct injected, if seafoam is put in the fuel tank it will go directly into the cylinder and bypass the intake valves.
When seafoam is sucked into the vacuum port on the intake mani(or TB) it will mix with the air coming into the intake ports and coat the valves on the way into the cylinders.
      09-08-2012, 10:40 AM   #8
ksalih
ksalih's Avatar
Drives: 2018 M2 LCI
..Thanks back to being on topic.. +111111 with replacing the oil soon after. I believe it changes the viscosity, therefore a change is necessary.
      09-08-2012, 10:49 AM   #9
Dave W.
Drives: Porsche 951, 1992 Eagle Talon
Maybe some of the seafoam got into the oil and cleaned the gunk off the oil temp sensor and now it's reading more accurately?
      09-08-2012, 11:26 AM   #10
clairvoyant
79
2007 335i  [5.24]
I always use this following guideline:
http://forums.bimmerforums.com/forum....php?t=1453384
Is it possible to have seafoam get into the oil?
I've done the seafoam treatment several times and the oil temperature gage never deviated from the normal (2 notches before the the half on the normal operating temperature).
Any idea?
      09-08-2012, 12:03 PM   #11
Ænema
14
Drives: BMW
The seafoam isn't going to effect oil temps. If I read that correctly, you're oil temps are 35F higher than normal? That would put you at 270-280F, that is not good.
      09-08-2012, 12:04 PM   #12
Dave W.
Any idea?
Right, it's unlikely to get it in the crankcase unless the ring seal is going bad, or you poured it in very quickly. It's more likely something else has changed oil temps or sensor reading. What were you trying to fix by doing the seafoam treatment?
      09-08-2012, 01:49 PM   #13
clairvoyant
79
2007 335i  [5.24]
Yes, the oil temperature is around 270ish.
I have no oil cooler, everything is stock. Outside temperature is around 86 F. I just recently changed oil around last week. What would cause this issue?
I use the seafoam to "supposedly" clean the carbon built-up.
I don't think it's the seafoam treatment but what else out there?.
      10-14-2012, 02:44 PM   #14
jvxbimmer
Drives: bmw 335i
stay away from seafoam !!!
I'm sure My direct injectors were going bad befroe using seamfoam. Last week I filled up my tank and added seafoam. By the time my tank reached 3/4 My engine gave up !!! smoke come out of the muffler, engine wasn't going over 300-400 RPM and was shutting off. My car is at dealer now $1800 to change injectors and spark plugs
I may be wrong about seafoam but will NEVER use it. I think its intended for 60s 70s American cars...
