When the @#$% can I wash my car???
07-24-2007, 12:02 PM | #1 |
54
Rep 731
Can't wash during the day because too hot and will get water spots? It takes me like 2 hours just to freaking wash it running hoses all over through the house to use the water softener..... I can't win..... sorry jsut frustrated
07-24-2007, 12:05 PM | #2 |
12
Rep 294
Just wash it with normal water, then rinse it with filtered water from a jug. The mouth of the jug has to be big enough so the water just sheets off your car. Like the sort of jug you make juice in, ya know? You should be scrubbin on your car when its hot though. Forget about about water spots; swirls are what you should worry about.
07-24-2007, 12:51 PM | #4 |
539
Rep 18,123
No shade available?
Current: 2010 Alpine White 335D LCI l 19" BBS LMs l KW V2 Coilovers l BMW Performance Grilles l MSport Front/Rear l Karbonwerke Trunk l F1 Pinnacle Tint 35% Former: E92 Space Grey 335i Latest pics |
07-24-2007, 01:15 PM | #7 |
335
Rep 2,385
Wash the car anytime bozo. I typically was my car during the day and I am not always in constant shade. The trick is to just keep the car constantly wet until it's time to dry. The fastest method is the water sheeting method, then use your leaf blower to get excess water out of the tough areas then use a nice waffle weave MF towl. You should have no water spots if you are quick enough. If you have any just wipe the car down real quick with a good QD like Poorboys Spray and Wipe or put a top coat of wax which will also remove your water spots.
This isn't exactly rocket science.
retired 06 E90 325i New: 09 VW Platinum Grey Jetta Sportwagen 2.0T SEL w/DSG, panoramic sunroof and Ipod adapter |
07-24-2007, 01:31 PM | #8 |
70
Rep 666
Here's one for ya......go buy yourself the Mr Clean Car Wash Kit.
When you are done washing the car (Zaino Car Wash Recommended) connect the Mr Clean Sprayer and turn the knob on the sprayer to the filtered water position. Then you can spray down the whole car and just let dry or take your time with a soft towel and No water spots. It costs like 25 bucks at Walmart. Later.
2009 328i Coupe Space Grey w/ Dakota LeatherSTEP, Sport Pkg. w Paddle Shifters, Prem. Pkg., Comfort Access, Grey Popler Trim, Heated Seats, Shadowline Trim, Xenon Adaptive Lights, GP Thunder Fogs, GP Thunder Angels, RE15mm Spacers, 35% Tint,OEM Alarm, Clear Corners, K&N, Strut Brace
07-24-2007, 01:42 PM | #9 | |
539
Rep 18,123
07-24-2007, 03:34 PM | #10 | |
335
Rep 2,385
07-24-2007, 03:36 PM | #11 |
blahhh
302
Rep 6,355
i live in northern jersey as well and i find time to wash my car on weekends around 5ish, and its not that "hot" its sunny yes but not hot enough that you can't wash your car. And besides washing is like 20-30min job after washing pull in the garage.
07-24-2007, 04:03 PM | #13 |
335
Rep 2,385
Really? No matter how dirty the car is? Good to know for future reference if it is that good.
07-24-2007, 04:27 PM | #14 |
418
Rep 12,276
My house faces west, so I have morning shade in the driveway, but it is lost quickly in the summer. I also get shade in the evening from the houses across the street. You just have to grab those windows of opportunity!
Water spots are not a problem if you dry the car with mf towels and do so in shade.
I think it is bad luck to be superstitious |
07-24-2007, 04:37 PM | #15 |
539
Rep 18,123
Yep. It's well documented on the Autopia.org forums. If those guys are willing to use it, it's good enough for me. I'm sure if you have caked on dirt from 4x4-ing you'll want to rinse things off first though.
07-24-2007, 05:52 PM | #16 |
Infrequent Poster
Rep 34
+1 on the Optimum No-Rinse (ONR). Started using it last winter when it was too cold out to wash outside. Now I use it all the time to wash in my garage and stay out of the sun. As mentioned above research it at autopia.org. The detail experts (Scottwax, Picus and others) all use ONR!
2006 325i
07-24-2007, 09:07 PM | #17 |
125
Rep 4,172
07-25-2007, 08:30 AM | #18 |
335
Rep 2,385
I may have to buy a jug for winter then. Goodbye laserwashes, hello winter handwashes
07-25-2007, 10:52 AM | #19 |
Rep 133
07-30-2007, 09:39 PM | #20 |
Bootleggin' 'n Gunrunnin'
137
Rep 2,372
For some shade, buy one of those cheap "easy-up" canopies at a local sporting goods store. Set it up over the car, run some water over all the surfaces to cool it down some, then begin washing. That is what I do if I don't have time later in the evening to wash.
My house faces east, so around 6 PM my drive-way is in full shade. But I've used the easy-up a few times when I needed to wash the car in the morning. Can't show up to a mid-day meet-n-greet with a dirty car!
Scott
2024 G01 X3 M40i, Brooklyn Grey Metallic /// 2015 F15 X5 35i, Space Gray Metallic, 99K miles /// 2013 F30 320xi, Mojave Metallic, 112k miles 2019 Ford F450 STX, Oxford White 2013 Ducati Multistrada Touring S, Red |
08-01-2007, 04:16 AM | #21 |
15
Rep 112
08-01-2007, 09:21 AM | #22 |
Rep 133
