Spark plug question
09-06-2012, 07:58 PM | #1 |
86
Rep 639
Spark plug question
I looked around, but didn't see an answer.
Does anyone consider changing plus on the basis of seeing a noisy cylinder (lots of timing corrections)... Or do most just go based on mileage or misfires... Just wondering |
09-08-2012, 10:31 AM | #2 |
71
Rep 510
Are you throwing codes? I changed mine because I was at the 40k mile mark and because I was having misfires in cylinder 5.
'2018 F87 M2 LCI | LBB | GC Camber Plates | Ohlins R&T 90/190N/mm | 18x10 et33 square 275/35 | MPe | Poly Transmission Mounts | Recaro Sportster CS
09-08-2012, 11:12 AM | #3 |
Rep 1
I just changed mine do to the misfire, you might have better luck taking it to a mechanic who can diagnose the car, cause a noisy cylinder doesnt sound like it would have to do with spark plugs
09-08-2012, 01:32 PM | #4 |
86
Rep 639
pretty sure you'd start to see timing corrections (noisy cylinder) (I don't mean actually noisy, like with sound) as an early indicator of crappy plugs or coil. Just haven't seen anyone talk about it. My car has been running nicely, last set of plugs around 42k, about to hit 60k, FBO plus e85 ~40% map
09-08-2012, 02:15 PM | #5 |
161
Rep 7,377
I would change them after 18k or once a year.
