Relaxing 2 oil lines $1,800?????
09-06-2012, 02:41 PM | #1 |
I <3 My E93
180
Rep 3,259
I had my 335i go in the BMW dealership to get my water pump replaced and one of the techs said they found that the oil line going to the turbos were leaking oil and it would cost $1,800 to replace.. They said its a 12 labor job + the oil lines
Is this correct??????
Bagged and Wrapped E93 335i
09-06-2012, 02:50 PM | #3 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
Now I just can't get the image out of my head of a technician talking calmly to the oil lines: "you're on a beach, it's warm and sunny, drinking a tall glass of 10w-40, life is good."
The i8 needs a V8 amirite?
09-06-2012, 03:00 PM | #4 |
EUROPROJEKTZ
187
Rep 7,958
Drives: backwards
I imagined tech massaging the lines.
LTMW|SPEEDELEMENT|EUROPROJEKTZ
#TeamStretchNPoke |
09-06-2012, 03:07 PM | #5 |
Some dude
92
Rep 1,780
If they have to pull the front turbo to get to both sides of the oil line (I think they do), then yes, that's about the right amount of time to R&R both turbos - book time at least. Then all new gaskets, o-rings, and other seals for the turbos, water pipes, oil pipes, etc.
RRT
E92 335i/6MT with stuff and things |
09-06-2012, 03:17 PM | #6 |
161
Rep 7,377
wow since you are there just upgrade them.
09-06-2012, 05:05 PM | #7 |
137
Rep 1,475
Drives: 🚀
Garage List 2015 BMW M4 [0.00]
2012 BMW 335IS (SOLD) [6.84] 2011 BMW 335XI (SOLD) [4.66] 2008 BMW 335xi (SOLD) [10.00] |
It's not covered under warranty??
2008 335xi E90 - Sold - > 2011 335xi E90 - Sold - > 2012 335IS E92 Crimson Red - SOLD > 2015 M4 Yas Marina Blue SOLD> 2019 McLaren 570s SOLD 2015 Lamborghini Huracan
09-06-2012, 05:36 PM | #9 |
15
Rep 447
are you on original turbos? any rattle? tell them to check turbo seals while there down there.
edit:just read above
2008 Bsm E92 335i - FBO -E85--------Sold
2014 BSM 335i Msport - Stock Last edited by Crazylegs; 09-06-2012 at 05:38 PM.. Reason: Stupid..... |
09-06-2012, 06:19 PM | #10 |
3441
Rep 79,211
09-06-2012, 06:57 PM | #11 |
11
Rep 442
Go in complaining of waste gate rattle and they will replace the turbos under the lawsuit that extends the waste gate warranty. I'm getting my smokey turbos replaced Monday, free of charge on my '07. You have
To make sure that your chief complaint is the RATTLE. |
09-06-2012, 07:37 PM | #12 | ||
I <3 My E93
180
Rep 3,259
09-06-2012, 07:41 PM | #13 |
915
Rep 3,456
Drives: Harrop E90 M3
Maybe it's related to the previous repair. Ask them to look into it, always worth a shot!
09-06-2012, 11:44 PM | #14 |
419
Rep 1,068
Ridiculous if they don't work with you. It's not covered under CPO? Are you modded? I'd see what you can bargain. Pull the history report to check if there were any repairs that could have affected this. If all fails call bmwna. Best of luck OP.
09-06-2012, 11:48 PM | #15 |
62
Rep 2,013
Cpo coveres engine turbos tranny and most major mechanical parts but not lines or gaskets.
And since they replaced the turbos not too long ago, they should definetly pay for the repair |
09-07-2012, 09:22 AM | #16 |
I <3 My E93
180
Rep 3,259
Funny thing is I just asked my service advisor and said if I do get both my oil lines replaced for $1800 and it leaks again is there any type of warranty?? He replies if the lines leak again then BMW will cover it under the unlimited warranty.... I got my turbos replaced at around 47,xxx (3/8/11) miles so would they have changed or messed with the oil lines then??? If they indeed messed with the oil lines then this should indeed be covered under the BMW unlimited warranty my service advisor told me
I think there just trying to make a quick $1800 off me
09-07-2012, 10:16 AM | #17 |
Some dude
92
Rep 1,780
I wonder whether they replaced all the o-rings on the coolant and oil pipes when they did your turbos. There are four coolant and four oil lines, each with an o-ring at both ends. Hard to say without seeing the turbos, but I'd think your leak is a bad o-ring and not a bad line. The oil feed lines are only under 70psi or so max.
RRT
09-07-2012, 10:25 AM | #19 |
3441
Rep 79,211
09-07-2012, 11:35 AM | #20 |
177
Rep 6,631
Replacing oil lines are the equivalent of doing a turbo swap. The manis need to come off as only the lower feed of the rear turbo is accessible without dropping the subframe.
You will also need an oil change while those lines are replaced.
E90 LCI N54 6AT
09-07-2012, 01:02 PM | #21 | |
I <3 My E93
180
Rep 3,259
No There oem oil lines
09-07-2012, 01:52 PM | #22 |
3441
Rep 79,211
