Procede guru's
09-06-2012, 02:15 PM | #1 |
Cookied
Rep 64
Procede guru's
Long story short, put the procede in rev 2.5 and had the 5-23 beta map loaded.
put it on and car felt good but didn't go past the 10lbs of boost. Yes I was on map one. .... bummed, I downgraded to 7-29 with firmware 108...just out of curiousity. logged it on map 2 and same thing not going past 10lbs. CANClear was off too and got codes 12140(flap) 11390(think thats cuz I have a sec cat delete) and 52647??? I can't find that one. Had a cobb prior and it threw p30ff codes so I switched. 3rd gear to 4th, traction off, about 77degs out. 7-29 autotune 6AT. Another question, I put it on as is from vishnu with the 6AT 5-23 map...but as seen there's stage 0 1 2 3 depending on your mods. Seeing all I was missing were dp's, I tried to load stage 2 and before I even started the car, I looked at the user adjustable settings and the numbers were way high... started the car and a long crank, sputter and half engine light.... so I just put the 7-29 autotune on, and car started fine. Appreciate any feedback......o and yes I was on the right map, not on valet
Procede///PWM///Cobb///KWv1///Helix custom 5 style/// BMS DCI/ //Helix fmic///AWE DV's///... simple daily
09-06-2012, 02:34 PM | #2 |
161
Rep 7,377
thats a stock like map, maybe VIN locked? do you see something flashing when running?
and the code you cant find is here: http://www.e90post.com/forums/showthread.php?t=533083 2C7E Lambda probe behind catalytic converter, trimming control : nothing to do with second cat delete to find the bmw codes just google the code to hex.....
09-06-2012, 05:29 PM | #3 |
15
Rep 447
don't run different firmware with different maps. there might be problems if doing so. rune the latest firmware and reload the latest maps.
2008 Bsm E92 335i - FBO -E85--------Sold
2014 BSM 335i Msport - Stock |
09-06-2012, 06:24 PM | #4 |
3441
Rep 79,211
09-07-2012, 07:56 AM | #5 | ||
Cookied
Rep 64
Not vin locked, I had a vin lock issue but sent the unit to get updated to 2.5, so no flashing. everything works fine as far as all the controls, guages etc. I see the map dials flash with the cruise control stick... so I just don't know. And the thread doest explain the code (52647) and yea code 11390 is the lambada probe one which is probably bad O2 sensors, but I started getting that after sec cat delete. Got the code with the cobb but it didt seem to affect performance. just popped up on idle sometimes and the car would start dropping idle and shaking a bit. turn off and back on, no problems. Quote:
I'm just going to reload everything and do another log
