09-06-2012, 01:16 PM | #1 |
Rep 23
Start / Stop enable or disable ...?
Coming from an E46 and an E60 to an F30 the amount of technology and features in my new 328is has is amazing and a little overwhelming. I love the comfort access. In the E46, I was the one in control lost it a little with E60 but with F30 its a totally new ball game. The amount of things the F30 3 series is doing in the background sometimes feels like it takes away from the BMW driving experience. One of the background features that is most interested and strange is the Automatic Stop Start (BMW Prius). All F30s come standard with Stop Start and part of BMW's "EfficientDynamics" move with all their cars. Stop/start is designed to save fuel while the car would otherwise be idling at traffic lights, back-ups, waiting to pick someone up, etc. The stop start functions differently depending on the transmission choice.
Automatic Transmission Stop/Start will shut off the engine whenever the car is brought to a stop, so long as the transmission remains in D and the brake pedal is pressed to keep the car from moving. The engine is shut off after approximately one second and the tachometer needle will point to the "ready" position. As soon as the brake is released the engine starts and you continue on as normal. The driver can also select P while the engine is off and release the brake pedal, by then selecting D again the car will automatically start. Manual Transmission Stop/Start will shut of the engine whenever the car is brought to a stop, the car is in neutral and the clutch pedal is released. The engine is shut off after approximately one second and the tachometer needle will point to the "ready" position. The car is automatically restarted when the clutch pedal is depressed and you continue on as normal. Interesting Quirks/Features The engine can be restarted by the driver in anticipation of driving off by: briefly applying additional pressure to the brake pedal or by releasing the break pedal slightly. Both will cause the engine to start. If "Automatic Hold" is activated the car will hold itself once the car has come to a stop and the engine has been switched off freeing the driver from needing to hold the brake pedal. Applying the brakes will cause the engine to start automatically. It is possible to prevent engine shut down once stopped in order to be able to drive off quickly. Within one second of stopping apply additional force to the brake pedal and then release the additional pressure and continue holding the brake pedal with "normal" force. Whatever that means. Why isn't my Stop/Start working? There are numerous vehicle parameters that are monitored as a part of the stop/start function to ensure the driving experience is not impacted. As many of the factors are not possible to monitor it may appear that the feature is not working. Reason why the stop/start may not shut down the engine include: The car is coasting (manual transmission) Brake vacuum reading is too low (manual transmission) Insufficient brake pedal pressure is being applied to hold the vehicle stationary (automatic transmission) Stopping on a hill/downhill with a 12% or greater gradient If the steering angle is more then 6 degrees If the steering wheel is still be moved after approximately one second of coming to a stop The system has not yet be activated by going over a speed of 5mph for automatics, 3mph for manuals since the last engine switch off If the gas pedal is being pressed (engine must be at idle speed only) You're coming to a stop from reverse The driver gets out of the car If Hill Decent Control (HDC) is activated If the engine is not up to temperature If the carbon canister is being purged if the grade of the fuel is too low for the engine Transmission adaptation is active (automatic transmission) The hydraulic pressure accumulator is not yet up to pressure (automatic transmission) Stop-and-go traffic - system is only activated by driving over 5mph for automatics, 3mph for manuals Batter charge is low Outside temperature is colder then 37.4 F / 3 C Outside temperature above 95 F / 35 C and the air conditioning system is on Fogging of the windshield is detected by the IHKA system Climate control system is on but passenger compartment has not yet reached desired temperature ABS system was used when coming to a stop Alternatively the car may automatically restart outside the standard restart procedure if: The driver is moving the steering wheel The driver presses the gas pedal The transmission was shifted from D to P and subsequently back to D The transmission is shifted to N or R The battery charge runs low Outside temperature rises above 95 F / 35 C and the air conditioning is on Fogging of the windshield is detected by the IKHA system Low evaporator temperature is detected Disabling Automatic Stop/Start The stop/start feature can be manually disable by pressing the button above the engine start button. Unfortunately there is no way to default start/stop off so the button must be pressed each every time to disable the system. Impressions I'll use the feature to entertain passenger and show off the technology of the F30 not as a gas saver..(If i wanted PRIUS i would have bought one!). The rare cases where I'm at long lights it is nice but my daily commute doesn't have enough lights to make the gas savings worth much. __________________ |
09-06-2012, 01:33 PM | #2 | |
Rep 64
09-06-2012, 01:35 PM | #3 |
BMW 4 Life...
149
Rep 3,360
I'm worried about possible engine failures?
I mean, it works for me just fine. But the number of times my car turns off then on, is ridiculous...will this have any future implications?
MODS: *** / M Sport + Performance / Meisterschaft / Challenge / MORR / more to come! ***
09-06-2012, 01:35 PM | #4 |
Rep 60
I remember reading somewhere in the manual that start/stop increases wear and tear on engine components, which is completely reasonable. Since I own this car and am not leasing it, I'm hitting that disable button every time.
09-06-2012, 03:01 PM | #5 |
99
Rep 2,323
Can you post that statment in the manual please? I believe the manual say it may cause wear and tear not it will.
09-07-2012, 01:34 AM | #8 |
11
Rep 217
This is an interesting one. When at a red light I don't mind the A.S.S. kicks in, but when I'm in the middle of the intersection to turn left, I'd rather have the engine running .... so, I guess I need to turn in already slightly .... will try this out !
2012 - F30 - 330d M-pack - Glacier Silver
1999 - Honda S2000 - Silverstone |
03-15-2014, 04:40 AM | #9 |
Rep 2
Thanks all, my stop start appeared to have stopped in the last couple of days and whilst I was sure whether it was me or the car, this read has answered my questions.
Having just been out, turned the AC off and stopped at a nearby island for more than a couple of seconds....the engine stopped and then restarted when I pressed the accelarator. Simple really... |
03-15-2014, 06:50 AM | #10 |
45
Rep 232
I always thought ASS gas savings were minimal at best, I mean how much gas are we really burning when waiting behind a red light for 20-30 seconds? The wear and tear it puts on the engine long term is more worrying to me.
04-02-2014, 09:59 AM | #13 |
Rep 6
I have been trying to get dealer to do something with switch. I hate it and have had several near misses when leaving my community and exiting on to a busy 4 lane highway. Was at dealer yesterday and asked them again. Nothing done. Can't wait to get rid of car.
04-02-2014, 10:05 AM | #14 | |
72
Rep 876
04-02-2014, 10:06 AM | #15 | |
51
Rep 1,831
Drives: 335i MSport + MPS/MPPK
04-02-2014, 10:25 AM | #16 |
773
Rep 1,502
I have too many traumatic memories of my '72 Olds Cutlass stalling in traffic during my high school years for me to ever be comfortable with auto start/stop.
I remember driving the car home from the dealer; when the engine cut out it was like delayed PTSD kicking in "Yaaaa OMG my car is stalled I'm going to miss my Calc test!!!" Hit the button to disable and haven't touched it since. |
04-02-2014, 10:32 AM | #17 |
130
Rep 1,101
I was told the dealer will do 1 time reprogramming so the Auto stop feature is turned to "off" as the default. If I don't like it and want it turned back to factory settings then it is my own $ to change it back. This is on a 2014 model I will be getting in July so they are still doing it once for free.
04-02-2014, 11:14 AM | #18 |
3262
Rep 6,299
In my car (2014 335i), it's set up to remember the last user input. So if I turn it off, it stays off until I turn it back on. Even if I turn the car off and back on later.
I leave it on though, the traffic around here makes it worthwhile to keep it on since I can spend long periods sitting at idle. It did, however, stall once. Released the brake, engine tried to start back up, decided it'd rather not and I just sat there until I threw the car in neutral and started it back up myself. |
04-02-2014, 04:45 PM | #19 |
Rep 6
1. I asked dealer yesterday to do something. No response.
Car was at dealer for 7 hours yesterday. I took it in for oil change and damaged tire. Dealer did 5 recalls and screwed up my day. They didn't fix tire and forgot about the switch. Time for a new dealer. 2. Stall was very similar to one noted above. When it happens in the middle of high speed traffic your brain can't react fast enough to figure out what has to happen next to get restarted. Very scary. 3. The switch is hidden behind the steering wheel. Why should I have to "remember" to set it every time I drive it. Last edited by Speedchromer; 04-02-2014 at 05:11 PM.. Reason: Add |
04-02-2014, 05:15 PM | #20 |
155
Rep 2,266
I have several long lights in my commute. It's never failed me in the 6MT.
As for engine wear, I don't think that's an issue. The starter would get the wear, but it's designed for this.
F30 Sapphire Black M-Sport 335i 6MT
04-02-2014, 08:24 PM | #21 | |
1435
Rep 4,724
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
04-02-2014, 08:55 PM | #22 |
54
Rep 1,025
Drives: G08 iX3
Did it stall while you were travelling at speed? Surely this is not related to ASS...
