29F0 code??
09-06-2012, 12:09 PM | #1 |
266
Rep 388
29F0 code??
Anyone ever got this? I'm running JB4, map 5. Only other mod is a DCI. I had been running a 70/30 mix of 91/e85. Ran the car down to about 1/4 tank then filled with 91. Car hesitates under heavy throttle and misfires. Any suggestions?
09-06-2012, 12:53 PM | #2 |
161
Rep 7,377
some kind of fuel mixture adaptation code. http://www.n54tech.com/forums/showthread.php?t=12040
mail Terry from BMS for support
09-06-2012, 01:06 PM | #3 |
266
Rep 388
Thanks.... That's the only result I found for the code when I googled it as well. Not very helpful. I've been experiencing everything from misfire codes on different cylinders to this one now. Its getting frustrating.
09-06-2012, 01:24 PM | #4 |
161
Rep 7,377
than you probably got more codes. just email Terry BMS for support.
