Logged 335is Today
09-05-2012, 05:07 PM | #1 |
Rep 69
Drives: 2008 335XI
Logged 335is Today
Hey what do you guys think of these logs? I did a 3rd gear WOT pull. Car is crazy fast tho...
Running: 2012 E92 335is Cobb Stage 2 Sport v401 AFE DCI AFE Throttle Body Spacer AWE BOV BMS Downpipes Im getting some codes too, maybe someone could help me. P112f P2d2e P2ded P29e0 P29e1 Thanks guys Last edited by Timore; 09-05-2012 at 05:13 PM.. |
09-05-2012, 05:15 PM | #3 |
Rep 69
Drives: 2008 335XI
I think i will do that this weekend and see what happens.
09-05-2012, 05:20 PM | #5 |
3441
Rep 79,211
Good idea.
I've seen some suggestions from your codes to update to latest firmware on the Cobb, clear codes, and re upload the appropriate map. Some of those codes are tuner and some are from leaving the Cobb plugged in. The others might be TMAP related or from throttle body spacer perhaps. Make sure everything is plugged in by TMAP sensor nearest throttle body and the sensor is clear of debris (as a last resort). |
09-12-2012, 05:24 AM | #6 |
33
Rep 230
I had the P29E0 (mixture control) code pop up yesterday. Did you find any solutions for your codes? 2007 E90 335i, Cobb Stage 2+ FMIC Agg v402, AFE DCI, & VSRF Downpipes
09-12-2012, 09:12 AM | #7 | |
161
Rep 7,377
If not clear the code, reset ecu and see if it pops up again.
09-12-2012, 10:14 AM | #8 |
Rep 69
Drives: 2008 335XI
Uninstalled throttle body spacer. No codes in 2 days... must be magic
09-12-2012, 12:18 PM | #9 |
33
Rep 230
Yes, I've been using it for two weeks now to give the car enough time to adapt. I'm getting ready to dyno and get a protune with PTF. Maybe my blend is off but I put 5gal of e85 with 11 gal of 93 w/10%.
