The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > The n54 isnt the only car limited up top by its twin turbos
      09-04-2012, 11:47 AM   #1
mithiral67
That guy
mithiral67's Avatar
117
Drives: 2015 Cayman GTS
Here is the results from my custom tune from AMS on my 997.1 Turbo. You can see what the engine can do down low similar to the n54 but with limited results up top.
Stock the 911 turbo generates 480 hp and 505 tq at the crank. Stock power expected after exhaust - 498 hp and 521 tq. So the baseline appears reasonable at 16% loss for an all-wheel drive car.
The car pulls north of .9 gs through 100mph. Feels amazing.
Thanks AMS for everything.
2015 - Cayman GTS - Stock
2011 - 335is e92 - Cobb PTF E40/Rob - Beck/AR/Helix (458 rwtq and 479 rwhp) - Retired
2007 - 911 Turbo - EP1/AMS (617 awtq and 500 awhp) - Retired
2008 - 335i e92 - Cobb/AR/Helix/OSS (384 rwtq and 356 rwhp) - Retired
      09-04-2012, 11:57 AM   #2
AlterZgo
1538
Drives: 23 X3 M40i, 21 911S, 24 Taycan
This is not surprising. Virtually every single stock turbocharged car is limited in upper RPM ranges because auto mfgs place a higher priority on boost response over ultimate all out power, hence the use of smaller turbos.
BMW seems to be trying to change this paradigm with turbocharged M-cars that can pull hard to redline. However, once you start turning up the boost in those cars, you will still run out of steam in the upper RPM range. I guess it's very similar to your Porsche where the stock tune makes max power at or near redline, but when you turned up the boost, there's not as much that can be gained in the upper RPM range compared to the lower RPMs.
      09-04-2012, 12:19 PM   #3
JamesM3M5
Some dude
Drives: E92 335i
The new tri-turbo M3/M4 will have two VATN turbine nozzles, which should eliminate the high RPM choking. Same with the diesels, but those don't rev that high. The straight 6 will be rev limited based on stroke and crankshaft harmonics, anyway.
RRT
E92 335i/6MT with stuff and things
      09-04-2012, 09:27 PM   #4
lonestar22
Ground Clearance?
lonestar22's Avatar
Drives: 540i & X5
at 115mph+ i was dead even with a 328i the other day. made me sad
E90 330i - E90 335i - E92 335i
      09-04-2012, 10:26 PM   #5
AlterZgo
1538
Please clarify. Seems like the N54 inline 6 has no problem making max power at high rpm/redline given the right turbo set up.
      09-04-2012, 10:45 PM   #6
son_of_siggy
15
Drives: CTS-V
He's saying the new stock turbo setup on the upcoming M3/M4 will not be rev limited by restrictions in the turbo system (like the stock 335i is) but rather by what the rotating assembly can actually take.
      09-05-2012, 07:05 AM   #7
DefactoM6
Sees the world the way it could be
Drives: '88 M6, '02 Z8, '09 E92 335i
617wtq. Gotta love Porsches! PS...the Sachs clutch setup is great, and you will certainly need it soon, if not already
      09-05-2012, 08:54 AM   #8
Alpina_B3_Lux
Alpina_B3_Lux's Avatar
263
Drives: Audi R8 LMX, BMW M550i xDrive
2009 335i  [8.90]
Would you mind explaining what that means? I saw that VATN means variable area turbine nozzle, but I don't have enough technical understanding to grasp what that means.
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
      09-05-2012, 09:00 AM   #9
JamesM3M5
Some dude
Drives: E92 335i
The turbine (exhaust side) has vanes around the turbine wheel that can pivot to push more or less exhaust against the turbine. At low RPMs, the vanes are moved to push gasses against the turbine, and at higher RPMs, the vanes pivot away to allow more exhaust gas flow without choking the engine down, which is where a small stock-style turbo chokes the engine out. So you get great boost response and higher boost pressures at low RPMs, less choking at high RPMs.
There was a video on the BMW tri-turbo diesels that shows computer graphic cutaways of the system working with the VATN turbos.
RRT
      09-05-2012, 09:13 AM   #10
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
really cool
      09-05-2012, 09:32 AM   #11
mithiral67
That guy
mithiral67's Avatar
117
Already shopping around.
      09-05-2012, 09:32 AM   #12
335i-boy
15
Drives: E92 335i M-Sport
Now that is awesome. Seems so simple when you watch the video.
Can't wait to see what a "tuned" next gen M3 will put out.
2008 E92 335i M-Sport | Sapphire Black | Sunroof | Creme Beige | Poplar Grey | Logic 7 | 6AT | 19" AG M359's | Michelin PS4S | LUX V3 | MHD V5 E40 | Steve AZ Walbro inline | Vishnu DCI | BMS CP | AR Design Catless DP's | Forge DV's | Helix IC | (Stock Cat. back) |
      09-05-2012, 10:30 AM   #13
joec500
125
Drives: it has 4 wheels
These numbers look amazing for a stock car + tune and bolt ons.
I actually just started shopping for a 997.1 to replace my 335i. Low mileage cars can be had for 70-80k, which seems reasonable for a relatively reliable entry level Super Car.
How has your experience been, going from a modded 335i to the P-Car?
      09-05-2012, 11:47 AM   #14
DefactoM6
PS, have you considered doing e85? My buddy who just picked up a 997.1 TT is supposedly getting the Protomotive e85 setup, and claims that the power made by e85+stock turbos is equal to upped VTGs on 93. Just curious if that was in the cards.
      09-05-2012, 11:55 AM   #15
plague
plague's Avatar
40
Drives: 335i sold :( / jb 20th AE
same here, hence my parts for sale in sig. although i have a first home purchase to make and then the car comes second a few months later. anything from a carrera s, turbo, or gt3. need to drive them all..
nice numbers op
07 335i- SOLD, and will be missed...
Parts for sale- PWM meth kit, M steering wheel, M shift knob, perforated e brake handle
      09-05-2012, 11:58 AM   #16
mithiral67
That guy
mithiral67's Avatar
117
Here is a write up I did comparing the two.
http://www.e90post.com/forums/showthread.php?t=694095
With more time behind the wheel, I am still in love with the car. The acceleration is brutal. AWD makes so much difference, there is no wasted power at low speeds.
Some negatives. The cost to modify are staggering compared to the n54. The car is obviously on a diet compared to the 335i. It weighs 10% less than the 335ix and chunk of that saves comes from sound reduction materials. Its not a noisy car, but its not quiet like the 335i. Only changed the oil once for about $250.
      09-05-2012, 12:01 PM   #17
mithiral67
That guy
mithiral67's Avatar
117
E85 requires more work on the fueling system. I want to keep the car as reversable as possible back to stock. I would prefer to hold off on changing the clutch as its a $5k+ hit. An E85 setup would definetely burn the clutch out instantly.
Also, I am already getting only 15mpg. With E85, I would be at the pumps every other day.
      09-05-2012, 02:11 PM   #18
nitehawk
nitehawk's Avatar
102
Drives: e92 335i 6MT
Why the wavy dyno plots?
      09-05-2012, 02:31 PM   #19
mithiral67
That guy
mithiral67's Avatar
117
Smoothing is at 3, less than the 5 most folks are use too.
      09-05-2012, 02:45 PM   #20
OpenFlash
Drives: A Lot
We are doing a flexfuel kit on our shop 997tt
      09-05-2012, 02:46 PM   #21
mithiral67
That guy
mithiral67's Avatar
117
Upgraded fuel system needed so far on yours? What type of numbers are you getting?
