Pulling Timing On 3-4 Shift Normal?
09-03-2012, 11:32 PM | #1 |
7
Rep 85
Here is a log of a 3-4 run. 50% ethanol. Cobb AP; otherwise stock.
Is it normal for timing to be pulled after a high speed shift across so many cylinders? I have another run where it does the same thing. My 5 4th gear only runs were perfect with no corrections, at all. |
09-04-2012, 12:17 AM | #2 | |
184
Rep 2,841
Happens on the 3-4th shift.... Myst can tell you more about his Cobb experience, but I think he and Dzenno have been working on a solution. |
09-04-2012, 07:32 AM | #3 |
177
Rep 6,631
Interesting, this is on a 6MT. I'd say contact Jake@PTF for a custom e-tune or Cobb for feedback. Do you have a log where it doesn't do this?
E90 LCI N54 6AT
09-04-2012, 08:33 AM | #4 |
184
Rep 2,841
I had a closer look at your data......and I am not a Cobb user.
BUT If I am reading things correctly, during 3rd gear your timing on Cyl#1 is running 12 degrees thru the midrange up to 5700 rpm and your engine is happy with no corrections, then it drops down to 8 degrees until you shift at 6700 rpm. That's weird. Timing will usually rise as rpms do. Then post-shift, there is a reading of 21 degrees for timing which then subsequently seems to set off timing corrections. I would be looking at the timing request tables These values don't seem right to me. |
09-04-2012, 01:29 PM | #5 |
Rep 180
Drives: BMW E90 M3 ZCP
Interesting.. My car run perfect except that I have the same issue with timing correction at shifting and will look into the timing tables. Thanks for pointing at the excess timing after shift.
E90 M3 ZCP 2010
E92 335i 2007 black edition |
09-04-2012, 09:52 PM | #6 | |
7
Rep 85
What I can't get around is why timing is so darn low after the shift. I thought that the Cyl 1 timing column was your map's timing less any IAT adjustments. Is it only 2-3 degrees because of the timing corrections? I thought those were independent and didn't affect this column. To give you an idea of the disparity, I am requesting 12-14 degrees (and its giving me 2 to 3). To address the 21 degrees of timing and add to the mystery; that 21 is from the plain Jane 401 map. No changes were made. In fact, the columns after the 21 degrees were modified to be a higher number than the 401 map. So, the disparity between the columns is actually LESS than the regular 401 map. Also factor in that I am running higher effective octane (reducing knock risk) and it makes me think that this was pulling timing to an even worse degree on the 401 map (for which I have no logs). I don't suspect that AFR is the problem, but I'd not rule out anything, I guess. Do you have any new ideas given this information? |
09-04-2012, 10:08 PM | #7 | |
7
Rep 85
Cobb was contacted today and a response is being hoped for. Why do you suggest I talk to Jake? Does he know something about this that you can share? With respect, and I'm sorry if I am misinterpreting you, but the goal is to tune myself and not pay someone else to do it, you know what I mean? I'd wager many more people are having this and have not logged it since we tend to focus on single-gear runs. |
09-05-2012, 12:59 AM | #8 |
177
Rep 6,631
I've been through this for over 2 years and only recently with the emphasis on logging are others coming forward with it. All I can say is pay PTF for the work. I've researched all these theories and such well before you guys. This is truly a case of ignorance being bliss.
It is fixed on my car and I don't even know how. If you ever figure it out, please let me know.
E90 LCI N54 6AT
09-05-2012, 08:58 AM | #9 | |
7
Rep 85
09-05-2012, 01:44 PM | #10 | |
Some dude
92
Rep 1,780
RRT
E92 335i/6MT with stuff and things |
09-05-2012, 06:17 PM | #12 | |
3441
Rep 79,211
I wish I had a definitive answer for either. I suggest contacting your tuners as they have more experience with problems. |
09-05-2012, 06:23 PM | #13 |
86
Rep 639
I am having the same thing. Between shifts actual load drops significantly so the dme is asking for timing in the 20s. As you push back on the gas it takes a moment for load to build thus timing too high, corrections start...
At least that's my 2cents |
09-05-2012, 09:14 PM | #14 | |
37
Rep 339
F10 535D XDrive (USA)
09-05-2012, 10:24 PM | #15 |
19
Rep 650
I've been working in this area lately and have noticed a few things. One is that the 3-4 shift is usually worse than the earlier shifts. The air charge temps are getting kinda hot at this point and there are spots in the Timing Total Cor. (Charge Air Temp) map such as 4000rpm and 75 load where it's not pulling nearly as much timing as it was at higher load. I think that contributes to the problem. Sometimes you also need to pull a little more timing in the main timing map in the 4500-5500rpm range at lower loads where you end up at on the shift.
Those changes can help, but I think there might be something else going on that makes it more susceptible to this but I'm not sure if anything can be done. I notice you have the same thing going on as I do where the rpm actually oscillates for a moment. Notice that your rpm goes from 5666 to 4900 to 5142 to 5064 to 5042 before it starts climbing steadily again. I don't know where our angle sensor is at but it would seem that the timing chain or something is slapping around on a hard shift and maybe making some noise and causing weird rpm readings at the same time...maybe even causing the ignition to fire at a slightly different time than it should relative to the crank? Just a thought... |
09-05-2012, 11:15 PM | #16 |
65
Rep 1,708
Hey good discussion guys. I think bog can be either ignition or boost. (EDIT:my bad you can just use boost mean Abs channel, so deleted my earlier comment)
Timing is reactive to load, so yes you’ll have higher timing with less boost… but boost is rising of course. Maybe try experimenting with the spool table by altering the y axis (rpm) and reducing timing here instead of your main map. I wonder how spool is defined in the DME. Carl, I think the varying rpms is just when the clutch catches… this should be reduced with a fresh, high force pressure plate. Log a fast part throttle (low load) shift and it should be a sharper rpm rise point in relation to throttle… assuming a proper shift. James, I almost think there could have been a slight change in either procede firmware at some point. Or potentially some difference in BMW, or for me Cobb throttle plate reaction mapping… not sure if there is such a thing, but seems like.it. Or the throttle motor could wear a little over time. It use to be easier to keep the throttle more open during a shift it seems. EDIT: As in another thread, a thought is that WG solenoids have some lag, or bleeding vac... ie, WGDC in the logs may not be actual output. Anyway, these are some of the points I’ve thought about. Last edited by Joshboody; 09-06-2012 at 02:09 PM.. |
09-06-2012, 08:04 AM | #17 |
Some dude
92
Rep 1,780
Good points all around. I'm shifting out of 3rd at around 6000-6200 RPM (stock everything except Procede + meth).
The crank sensor is right around the #6 cylinder inside the engine. Not sure whether that would cause timing shifts due to torsional vibration, but BMW read the crank sensor off the vibration damper up until 1996 when OBD2 came out. I'd imagine it was worse on that older setup. I think my boost is getting a little slow to respond - just a tiny bit. I'll test my solenoids for leakage, and probably have to replace some vac hoses. What exactly causes "bog"? I'll of course have to log, but I just don't have a great place to do 3rd/4th gear pulls - way too many state and county cops in my area.
RRT
09-06-2012, 10:39 AM | #18 | |
177
Rep 6,631
Try doing a wot shift on high boost at around 5500-6000 RPM, it won't bog. Do it north of 6000 it will bog, especially in the higher revs. Have you considered the NLS/2-step? I heard this fixes the bog.
E90 LCI N54 6AT
09-06-2012, 10:41 AM | #19 | |
177
Rep 6,631
Unfortunately, NYC pump gas must be crap because I can't get much power out of pump gas only safely.
E90 LCI N54 6AT
09-06-2012, 10:45 AM | #20 | |
177
Rep 6,631
E90 LCI N54 6AT
09-06-2012, 10:46 AM | #21 | |
19
Rep 650
09-06-2012, 10:51 AM | #22 | |
177
Rep 6,631
I also have the same issue with the massive timing drops post-shift on my 6AT, but PTF has fixed it. I don't know how or where he fixed it as there is nothing evident in my logs that show anything changed.
E90 LCI N54 6AT
