BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > meth tubing that comes with vishnu kit
      09-03-2012, 09:36 PM   #1
scottro
scottro's Avatar
17
Drives: E70 X5M
Am I missing something obvious? I need to order additional tubing as I plan to move the kit to the trunk, and I have measured the tubing that came with the kit to have the following specs:
1/4" OD
3/16" ID
1/16" Wall thickness <-- this is important that it is not 1/32"
Searching McMASTER-CARR (http://www.mcmaster.com) and a few other industrial websites, I cannot find any HDPE or Teflon PTFE that meets those specs.
As soon as I set search requirements to have a 1/4" OD (necessary because the hose slides inside compression nut), and a wall thickness of 1/16" (important because this increases the maximum PSI it can withstand), I only seem to get options of 1/8" ID.
Am I messing up the measurements of the original tubing or something? Didn't think it would be this hard to match ...
      09-03-2012, 09:40 PM   #2
jpsimon
Team Zissou
jpsimon's Avatar
Drives: 2022 AWD M3 Comp - SMB
When I swapped to the trunk I used this tubing:
http://www.mcmaster.com/#catalog/118/132/=j506dc
"Choose-A-Color Flexible Nylon Tubing, .170" ID, 1/4" OD, .040" Wall Thickness, Black, 25' L"
Part # 5548K84
      09-03-2012, 09:46 PM   #3
scottro
scottro's Avatar
17
Drives: E70 X5M
Part # 5548K84
Thanks. Does it not bother you that the chemical sheet gives Nylon a 'B' rating, which says:
Moderate Effect—Some chemical resistance. Some performance degradation. Shortening of product life.
I've been looking at the other plastics mentioned in the original post because they get the A rating "No Effect—Excellent chemical resistance. No performance degradation."
      09-03-2012, 09:52 PM   #4
jpsimon
Team Zissou
jpsimon's Avatar
definitely missed that! could have sworn I read it differently when I ordered. I'll just keep an eye on it I guess.
I'm pretty sure this is the exact stuff vishnu supplies with their kit if you want to just get it from howerton:
http://www.howertonengineering.net/p...r-foot%29.html
      09-03-2012, 09:58 PM   #5
scottro
scottro's Avatar
17
Drives: E70 X5M
You're probably fine with Nylon .. I hope I didn't make you worry about your setup now
Thanks, I'll check it out too.
      02-05-2013, 10:06 PM   #6
creaminz
creaminz's Avatar
Drives: E90 LCI
Thanks for that link jpsimon. So it is 6mm not 4mm ? On howerton website there are 4 & 6mm just want to make sure before i place an order.
      02-05-2013, 10:30 PM   #7
Richurd
Richurd's Avatar
Drives: Too slow.
6mm is from pump to the split. Once it's the split where it "y" it goes into 4mm
07 e92 335i | BSM | SB | Gray Poplar Wood Trim | 6MT | Premium | Sport | Cold Weather | iDrive | Logic7 | Comfort Access |
      02-06-2013, 01:10 AM   #8
caliguy562
8
Drives: E92 335i
This is correct. And the kit uses 1/4 inch hose from devil's own. It is written on the tube. 6mm is what I'm using now. However, 6mm will not work with 1/4 tees if you ever use any down the line. 6mm is smaller than 1/4"
      02-06-2013, 09:37 AM   #9
DevilsOwn
Drives: Triple black
We do get a custom blend of tubing produced. It is base is nylon 11 but like i said its not an off the shelf item.
      02-06-2013, 11:29 AM   #10
creaminz
creaminz's Avatar
Drives: E90 LCI
Guys what about the very skinny clear tubing that comes with vishnu kit. I am using that tubing on my intercooler nozzles and one of them snapped, where can i buy more of them clear tubing
      02-06-2013, 04:37 PM   #11
Bme30
Bme30's Avatar
88
Drives: 335i coupe
2007 335i  [0.00]
is the vishnu 4mm or 6mm?
i need new tubing also!!
      02-06-2013, 05:02 PM   #12
creaminz
creaminz's Avatar
Drives: E90 LCI
4 x 0.75
I just ordered 4mm from Howerton Engineering, hopefully it's same size tube lol
      02-06-2013, 05:08 PM   #13
Richurd
Richurd's Avatar
Drives: Too slow.
The clear tubing after the FAV is 4mm. Before FAV it is 6mm.
4mm clear hoses
Product description:Used after the HSV / FCM and FAV in most kits.
6mm tubing
Product description: Used from the tank to pump, and pump to HSV/FCM and FAV in most systems.
Vishnu uses 6mm to run up to the FAV. After the FAV, it turns into the 4mm clear tubing. Check above links.
      02-06-2013, 05:48 PM   #14
Bme30
Bme30's Avatar
88
Drives: 335i coupe
2007 335i  [0.00]
4mm clear hoses
6mm tubing
you are the man!!!!!!
