Trouble removing stock rubber elbow from charge pipe
09-02-2012, 06:10 PM | #1 |
9
Rep 255
Found a single thread on how to remove the band that connects the rubber elbow to the charge pipe.
http://www.e90post.com/forums/showth...7#post12614947 I took out the charge pipe and could not pop off the band using a flathead like the posts on this thread claimed. Has anyone dealt with this before? Rather not use the cutting wheel unless I have to
2007 BSM 335i ZSP/ZPP l JB4 G5 ISO l E85 l BMS FLASH l METH l DCI l DPs l Twin BOVs l Scoops l 18" Forgestar F14sl Koni Yellows l Swift Spec-R l GForce Rivals/Slicks l Quaife LSD |
09-03-2012, 10:41 AM | #2 |
133
Rep 4,764
Had to cut mine off. Wear good eye protection.
09-03-2012, 11:54 AM | #4 |
9
Rep 255
Figured it out finally! To anyone with this problem, make sure you take off the charge pipe all the way. Don't put the screwdriver directly under the tabs, instead just a little off to one side. Be persistent
