Virtual Dyno sharing thread
09-02-2012, 08:03 AM | #1 |
Rainbow Racer
1008
Rep 2,539
It's a fun software to use, but I wanted to compare other peoples runs. This is on a relatively flat surface, anyone near the Bradenton/Sarasota, FL area can attest that being right on the coast = pretty flat land.
My mods on this run: JB4 G5, E50 blend, DCI, Methanol, 17.8psi tapering to 15psi @ redline
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
09-02-2012, 09:43 AM | #2 |
Rep 169
If you don't mind, could you paste your txt log file as well. Also, the weight of your car as used by virtual dyno, gear used in the pull and the gear ratio.
I'm curious as to how the results compare to what I would calculate.
|Cobb AP / JB4 | DCI | BMS WW Meth Kit | AMS FMIC | Macht Schnell 3" DP |
09-03-2012, 07:20 AM | #4 |
Rainbow Racer
1008
Rep 2,539
I never thought about adding the weight of the driver as well. My results above are skewed then.
-Loe P.-
09-03-2012, 07:21 AM | #5 |
Rainbow Racer
1008
Rep 2,539
Why the drop in A/F ratio? was that intended?
-Loe P.-
09-03-2012, 07:55 AM | #6 |
161
Rep 7,377
u running this on stock turbos? almost 0 taper
09-03-2012, 08:22 AM | #7 |
15
Rep 329
Drives: 08' 335i, ZHP 330i
Bone stock w/wagner FMIC, OEM paper filter, Stg1+ custom ATR map (by me), 150ft elev, 88* 95% humidity
09-03-2012, 09:23 AM | #8 |
79
Rep 2,396
Drives: '08 E90 335i
SO many turbos about to get toasted by ATR
**Not ATRs fault, people just not decreasing boost at redline |
09-03-2012, 09:59 AM | #9 |
161
Rep 7,377
17-18 is what i am confident to push myself with stage 2 upped turbos. for stock turbos is too much . max 15 psi.
09-03-2012, 07:05 PM | #10 |
51
Rep 923
I am running 80% meth so when meth is flowing on my particular car, I run a little on the rich side. I am in the process of manually adjusting my map to get my AFR target in the upper 11s under WOT. Right now they are in the low 11s/high 10s which is richer than necessary.
There is more of a taper (down to 16 psi) if I ran it to redline, but I shift around 6000-6200 so the taper isn't appearing like all that much. I am FBO+Meth and don't run this aggressive all the time, but the log was solid aside from being a little on the rich side. |
09-04-2012, 07:49 AM | #11 |
Spreads VD
Rep 23
Hey its running on a MAC
09-04-2012, 08:43 AM | #12 |
15
Rep 329
09-09-2012, 12:09 PM | #13 |
15
Rep 329
stg 0 vs stg1+ E50 custom
T |
09-10-2012, 01:45 AM | #15 |
40
Rep 70
Drives: E92 M3, E92 335i
Corn on the Cobb (~45% ethanol), compared to some other maps.
E92 M3 - Space Gray | E92 335i - Alpine White
If you can leave black marks on a straight from the time you exit a corner till the time you brake for the next turn....... Then, you have enough horsepower. |
09-10-2012, 01:58 AM | #16 |
278
Rep 5,062
Drives: Black e92 335i
JB4 Map 5 - FBO
PUMP GAS
JB4 / OSS Angel Eyes / Downpipes / F1-Racewerks FMIC / Custom Meth Kit / BMS DCI / ER Chargepipe / HKS BOV / BMS Meth Elbow / BMW Performance Exhaust / Carbon Fiber Inlay Quad Tips / 19" Miro 111 / Front Aero Lip / M3 Sides / VRS CSL Trunk / Mtech Rear / DD CF Quad Finned Diffuser / LCI Tails / BBK / Smoked Reflectors / F1 Euphoria LED Interior / License LED's / GT 5000k Corners / 5000k HID Fogs / Air Scoops / LED Turn Signals / FK Silverline Coilovers / HPA endlinks / Vibrant Resonators / Osram CBI 5000k D1S
09-10-2012, 05:06 PM | #17 |
15
Rep 329
red run is my newest E50 map, bone stock/wagner FMIC/OEM paper filter blue is stg1+ agg 93 oct green is stg1+ agg E25 T |
09-11-2012, 07:02 AM | #18 |
Rainbow Racer
1008
Rep 2,539
Virtual Dyno's look great! I hate that my turbo's don't spool as fast as some of you other guys, DP's will definitely cure that for me.
-Loe P.-
09-11-2012, 07:26 AM | #19 |
Spreads VD
Rep 23
Thats impossible since a MAC is technically all PC hardware running a different OS.
09-11-2012, 07:33 AM | #20 |
33
Rep 230
I attempted to log and post some 3rd gear runs but the virtual dyno was throwing some low numbers and the graphs were all over the place. Can someone look at my logs and see what I did wrong. I'm running vrsf dp's, dci, aa sport intercooler, cobb stage 2+fmic, and e30 blend. Car is a 2007 6at with fresh plugs and one coil recently replaced.
09-11-2012, 08:51 AM | #21 |
13
Rep 233
2008 e90 335xi
50/50 meth 40% e85 w/92 octane AR Downpipes BMS DCI intake JB4 at latest firmware, 45 additive, map 3 15ohm 195lbs driver weight + 2 baby seats + full golf bag/shoes +roadside emergency kit+ full tank of gas (just filled up) I'll do another run, as I've added an AMS intercooler and bumped the additive since this one, plus I'll use the same VD settings as you guys. |
