F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > HK rattling side skirts
Extreme Powerhouse
      09-01-2012, 10:23 PM   #1
rxander
rxander's Avatar
16
Drives: F30 Alpine White
For anyone that listens to music with a lot of bass I know this has come up as an annoyance. On the inside its barely noticeable but turn up your radio and step outside the car and you will hear very ugly rattling coming from the side skirts.
Curious if anyone found any workarounds or temp fixes?
      09-02-2012, 10:53 AM   #2
wayman519
79
Drives: E82 N52 6MT A51
2018 BMW X2  [0.00]
2009 128i  [0.00]
Take it to you dealer. This is a 50k+ car. they'd better sort that out. Its not suppose to sound like a chintzy rice rocket when you crank music.
      09-02-2012, 07:52 PM   #3
rxander
rxander's Avatar
16
Ok Wayman519 thanks for the response. Looks like my situation is an anomaly and not the norm for stock f30s. Will check in with the dealer. When I touch the rear part of the side skirts they wiggle. Does yours ?
      04-22-2013, 07:22 PM   #4
UhhItsANT
Drives: 2013 BMW 335i
2013 BMW 335i  [0.00]
did you happen to find a fix for this yet?
      04-22-2013, 10:09 PM   #5
rxander
rxander's Avatar
16
Yeah I brought it in couple months back. The rattle it turns out was inside the front passenger door panel. Something wasn't sealed properly. No more rattling.
      04-22-2013, 11:07 PM   #6
UhhItsANT
ooo ic. mine seems to be coming from the side skirts. if i put pressure on it, it stops.
      03-06-2014, 10:16 AM   #7
juice4434
Drives: BMW 320i
same problem
Im actually relieved I'm not the only one ... im here in Malawi and had a custom install done before my car was imported , the side skirt / door rattle is killin me ...inside its perfect , but if you're outside it sounds like an 86 Toyota corolla with a budget boom box
any genuine solutions on this (DIY ofcourse)
      03-06-2014, 03:11 PM   #8
sirfatty
Code Monkey
Drives: 2013 328I
im in the same boat. im temped to just pull them off and dynamat the hell of out them but id rather not because of the weight
      03-06-2014, 05:56 PM   #9
mcli
_________
mcli's Avatar
Drives: 2014 335i 6mt
Has anyone tried pulling the under-seat subs, adding dynamat, then re-install?
      03-06-2014, 10:17 PM   #10
UhhItsANT
what i tried to do while standing outside is pushing the side skirt up towards the car and it helps.... so its something between the skirt and where it attaches.... i think the skirt has to be remove in order to fix it.
      03-09-2014, 11:49 PM   #11
MVD
MVD's Avatar
Australia
Drives: 2016 BMW M2
Have the very same issue here in Perth, Australia on my 2013 F30 328i with HK sound. Rattling was unbearable so I took my Beemer back to the dealer where they apparently added foam into the side skirts. Fixed the problem from about a month, now the issue is back. Will bring it up again with the dealer at my next service.
Annoys me, as it must annoy everyone else! This sound system by HK was apparently designed together with the birth of the F30! Hmm...
      03-11-2014, 09:57 PM   #12
GL888
7
Drives: 328i F30 m sport
I had the same issue in Sydney, they said it was a common problem. They fixed and it has come back so they to add more foam and seal I think.
      03-11-2014, 10:55 PM   #13
HFW003
HFW003's Avatar
Australia
5697
Drives: 2024 M340i xdrive
I've got exactly the same issue.
I've for to go in for an oil change soon so I will get them to look at it.
      07-30-2014, 02:46 PM   #14
retiredmarine
49
Drives: 2014 328i msport
Same issue here. sounds good on the inside, rattles on the outside!
      07-30-2014, 03:47 PM   #15
Fronzdan
Drives: '24 M240 xDrive
Same here. I think this is "normal". The side skirts are probably only attached in a few places. You can wiggle them. I would think removing them and putting 3M tape the full length would fix it.
Who's gonna try it first?
      07-30-2014, 08:48 PM   #16
GL888
7
My car has just gone in again as a result of this issue.
I'll let you know what they've done.
f30post
