Help!~7-29 Autotuning datalog~
09-01-2012, 06:53 PM | #1 |
17
Rep 283
Hello.
I running the 5-23map My car is too slow. because I can't found the Better fuel. So I try to use the 7-29 autotuning map. The Autotuning is ON. Please give me some advice. Thanks |
09-01-2012, 07:04 PM | #2 |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
You did update to the corresponding firmware, right?
Cobb E40 PROtune by Jake@PTF/RR catless DPs/aFe DCI/ETS 5" FMIC/ER CP/Forge DVs/Alpina B3 TCU flash/BMW Perf. Exhaust./BMW Performance Style 313s/M-Tech Rear
09-01-2012, 07:12 PM | #4 |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
Ok good. Just checking. I'll let the resident data log guys comment on our graphs. I'm still learning!
09-01-2012, 07:28 PM | #5 | |
17
Rep 283
Because my English not very well. But My brother in U.S I will ask for his help. If you to my datalog have any Suggestions, please tell me. thanks |
09-01-2012, 08:18 PM | #6 |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
Your English is better than most Americans on here! Good luck!
09-02-2012, 05:16 AM | #7 |
161
Rep 7,377
Without octane there is so much you can do. You should consider getting a meth kit and run map 4
