1/4miles @13.2s 109mph is too slow~
08-31-2012, 07:51 PM | #1 |
17
Rep 283
Hello everbody. I have the procede rev3 in my car a mouth ago.and I can't feel my car fast more than stock.I use the AFE INTAKE and Ak cat-back.Runing the 97 fuel in China.Like the 91oct in U.S and this is my datalog.I can set boost 18psi.But my car still slow.. 1/4miles @13.2 109mph v-box 0-100km/h 5.0s 64-160kmh @8.4s 100-200kmh @12.5s too slow!! |
08-31-2012, 08:05 PM | #2 |
60
Rep 333
Yeah, that seems a bit slow. I took my bone stock 07 335 sedan with AT to a 1/8 mile track and ran it on the stock runflats (car only has 25k miles). I was able to get a decent 8.5 @ 86 mph (probably around 13.4 1/4) with only a little bit of brake boosting off the line and traction control on. That was the first and only run due to rain hitting just after.
You may just be having traction issues off the line.
11 E92 ZCP
02 Honda S2000 -741 whp 471 wtq (dynojet) @ 29.6 psi on e85; now on 34 psi, 800+ whp. Last edited by Spoolin1; 08-31-2012 at 08:11 PM.. |
08-31-2012, 08:07 PM | #3 |
112
Rep 2,856
Drives: 2011 335is E93
109mph is a low-mid 12s I believe....you're either not hooking, launching properly or shifting properly....look up 1/4 times at that mph.
I think you're running fine for your mods, it's just a matter of practice. Don't feel bad...for example. I have JB4, Stett CAI & FMIC...ran 14.1 @ 104.8mph -I need some more practice and need to figure out my traction config., but clearly I can't hook from the start and I lose all my time there. I should be running high 12s.... |
08-31-2012, 08:35 PM | #4 |
12
Rep 232
your trap is not that bad
remove your cats for more power
2007 335i coupe AT-- I80AS--FBO -stock turbos--COBB v402 beta stage 2 + ATR-- NITTO'S 275-40-17 NT05R --- 12.025 @ 120 mph -- full weight
08-31-2012, 09:18 PM | #5 |
177
Rep 6,631
holy timing corrections batman.
OP, your fuel in China must be complete crap. You need to run methanol or E85, both of which may not be easily available out there. I don't think there's not much you can do to fix that as-is.
E90 LCI N54 6AT
08-31-2012, 09:25 PM | #6 | |
17
Rep 283
My car has 30k miles.. |
08-31-2012, 09:29 PM | #7 |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
What was your 60 foot time? (prob don't measure that in feet in china, right?). That should give you an idea of whether it's your launch that's the issue. I was FBO minus intercooler with stock RFTs and full weight 50/50 E85:93 and it was my first time at the track. I was running low 13s because I suck! I ran four runs and my best times were with traction control fully on!
But if you combined my best 60' time with my last run I'd have run a 12.89x, which is a bit more respectable I think. Btw, the air could've been an issue, too. There are so many factors at play here.
Cobb E40 PROtune by Jake@PTF/RR catless DPs/aFe DCI/ETS 5" FMIC/ER CP/Forge DVs/Alpina B3 TCU flash/BMW Perf. Exhaust./BMW Performance Style 313s/M-Tech Rear
08-31-2012, 09:36 PM | #8 | |
17
Rep 283
I can buy BMS PWM and Vishnu PWM.But I am worried that it will be on fire~ The insurance company will not make up for my loss. Can I use the 99.7% ethanol 50% and 97 50%? I know this is a crazy idea , but I have no choice . |
08-31-2012, 09:45 PM | #9 | |
177
Rep 6,631
Do you have ethanol in China? If so, try 3 gallons of pure ethanol with the rest of your best quality pump gas and try again. Your car is not happy with the pump gas as-is. The methanol (PWM) kits can greatly reduce the risk of fire if you put the methanol reservoir in the trunk. Do NOT use WW tank for methanol.
E90 LCI N54 6AT
08-31-2012, 09:48 PM | #10 | |
17
Rep 283
60MPH≈96kmh 90-100kmh 4.29-4.97s I think 60mph≈4.68s |
08-31-2012, 10:02 PM | #11 | |
17
Rep 283
3gallons and 3gallons 97? |
08-31-2012, 10:19 PM | #12 | |
17
Rep 283
99.7% ethanol≈$10.5USD/gallon... In China the 97 gaosline ≈$4.6USD |
09-01-2012, 02:01 PM | #13 | ||
14
Rep 455
you want cheap ethanol, grow some corn and make your own
JB4 G5 / VRSF IC / STETT CAI / GREDDY / custom exhaust / iRotora cross drilled rotots / snow stage 3 meth / 19" iForged senekas / upgraded speakers n CF woofer box / M3 bits/ DINAN camber plates/ KONI/ megan racing toe arm/ supreme power lowering perch
09-01-2012, 02:08 PM | #14 |
Rainbow Racer
1008
Rep 2,539
+1 that is a boat load of timing corrections.
I would try turning down the boost to 15-16psi or spring for meth
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
