Does A Single Turbo Have Bad Lag? Logs Inside
08-30-2012, 07:46 PM | #1 |
307
Rep 5,175
I have been working through my review of the Vishnu/FFTEC VFF700 (PT 6262 CEA Turbo) and I am getting toward the end of the review. I won't give a timetable for completion, but I have a ton written already. While I was doing some of the testing, I thought I might post a quick log showing how fast this car gets into boost on my single setup. My review will include a lot more data on this, but here is one log to enjoy.
During this testing, I am looking to quantify how long it takes for the car to reach 10 psi and 20 psi after going WOT (TPS 100%). I always say you drive a car in it's powerband. That would mean you don't floor a Ferrari at 2k rpms and expect it to accelerate like it would at 5k rpms. In this log, I started with the at about 3700 rpms in 2nd gear and floor the car so you can see how fast the turbo comes on when the car is in the powerband. Notice I go full WOT at exactly 2.0 seconds. The car reaches 10 psi in just 0.73 seconds and reaches 20 psi in 1.01 seconds. This shows just how fast the turbo hits and just how fast you get to 500 rwtq on my car. I will do this testing for 2k rpms and 3k rpms in my review.
654 RWHP ... ! Vishnu/FFTEC Single Turbo 335
08-30-2012, 08:47 PM | #3 |
48
Rep 1,010
Thanks for posting.. Glad to see updates.. The real test will be from the lower rpm range.. This setup has more potential top end, but if from the lower powerband it can spool quickly.. We've got ourselves a winner
2008 335xi Jet Black//Coral Red VTT Stage 1+// Procede V5//VRSF DPs//AMS FMIC//KW V1//M3 Sways & Sub Bushings// Alpina AT flash Apex EC-7//Michelin PSS//Dinan CAI |
08-30-2012, 09:31 PM | #5 |
307
Rep 5,175
I kind of disagree. I think this speaks huge volumes about the capability of the car. If you drive an M3 and try to take off at 2k rpms, then it won't pull and it is the driver's job to know the powerband then keep the car there. I never drive at 2k rpms. At bare minimum, I am at 3k rpms because I know the powerband of my car.
08-30-2012, 10:04 PM | #6 |
8
Rep 330
Do you find it spools quicker with meth? I just wasted 2 gallons of meth in the hills, and thought I felt a faster spool. Also I was screaming like a little girl and will never run the car without meth again.
FFTEC 6466 6mt 335i | FFTEC GTX3076R Evo IX
08-30-2012, 10:08 PM | #7 |
40
Rep 462
People are really spoiled with our twins they should jump in a stock evo or sti those cars have major lag from factory And I feel like nobody complains about that as long turbo can make the stock boost curve the lag is really the transition from 300hp to 600hp not 100 hp to 600hp like some evos I know
Irub |
08-30-2012, 10:09 PM | #8 |
307
Rep 5,175
I am in the process of doing that testing. I will have answers tomorrow on that.
08-31-2012, 01:06 AM | #10 |
8
Rep 330
You mean with regards to boost response right? Aren't you single turbo?
08-31-2012, 04:48 AM | #11 |
8
Rep 395
Define lag! You cannot race from 2k rpm whether its on stock, Rbs or single turbos, therefore lag would not be even mentioned when racing as you would probably be around 4k rpm anyway.
When you want to show lag, you want to show normal street driving into an increase in speeds, overtaking perhaps without the need to rev the shit out of a car. Its there where you say omg this car is so slow to get to speed or after taking a ramp to highway stuff like that when you're not in spirited mode. Starting a pull at 4k rpm and saying theres no lag from 4-7k rpm is not so much convincing.
COBB S2+ - Mr.5 CAI, Catless DP, Catless MP, AMS FMIC. |
08-31-2012, 05:53 AM | #12 | |
40
Rep 462
Irub |
08-31-2012, 06:37 AM | #13 | |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
It would also be interesting to get the logs for the 58mm since that's what most AT guys will have to run.
The i8 needs a V8 amirite?
08-31-2012, 06:42 AM | #14 |
68
Rep 1,432
08-31-2012, 06:50 AM | #16 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
Everyone seems to criticize that feature
08-31-2012, 08:07 AM | #17 | |
48
Rep 1,010
08-31-2012, 08:16 AM | #18 |
15
Rep 432
Two different animals. Doesn't make sense to pigeonhole the singles powerband into a direct comparison with the twins. All that shows is how lazy drivers can get away with being by not shifting into the proper gear when asking for power. Boosted had it right on. You wouldnt overtake in a Ferrari startingat 2000 rpm. Why judge it based on that?
08-31-2012, 12:56 PM | #19 | |
8
Rep 330
http://www.e90post.com/forums/showthread.php?t=735215 RBs spool at about 3000rpm: http://www.e90post.com/forums/showthread.php?t=480025 Stockers spool at about 3000rpm: http://www.e90post.com/forums/showthread.php?t=735589 Did you want response times at various RPMs? FBIS is working on that.
08-31-2012, 01:05 PM | #20 |
30
Rep 685
The discussion here is basically talking about two different things. FBIS is showing the transient response that this kit and particular turbo has (which is in my mind "turbo lag") on the N54.
Initial spool up characteristics are important as well, but dropping a gear to be in the meat of the powerband is something you do on pretty much any car. Knowing that how quickly a particular setup will pick up steam when this is done is really the issue. From the graphs FBIS posted, it looks as if this particular setup has pretty impressive transient response. |
08-31-2012, 01:37 PM | #21 | |
16
Rep 227
That's to say ... stock turbos pushing 20psi != RB Turbos pushing 20psi != TD Turbos pushing 20psi != ASR Turbos pushing 20psi != PT Turbo pushing 20psi PSI are not the only characteristic of generating power - at what level of efficiency did it take to get there (ie heat generated in the charge and other characteristics). I think once FBIS is done with his testing and published how he got the numbers. I can try to duplicate it and give another data point for 6AT 58mm. I would love to see some one with a 6MT try a 58mm setup. I think there is more top left in the 58mm than what a 6AT can show. That being the case, it spools even faster than the 62mm. But all this 100% E85 progress might push the 6MT+58mm to its limit. Who knows. :0 |
08-31-2012, 01:40 PM | #22 | |
16
Rep 227
I can say that the 58mm setup is somewhere between stock/RB and 62mm. For giggles, let's say its halfway between -- 3300 RPM. Is a 300rpm difference detectable as "laggy" for daily driving? For a 6MT, I would say "no". For a 6AT, I would say "its hard to detect the little difference" - dynobutts may vary. |
