Engine Malfunction - Reduced Engine Power
08-29-2012, 09:35 PM | #1 |
40
Rep 373
Hi, everyone. I have two issues with the car, which might be related:
1: In the past 6 months or so, immediately after a hard acceleration, after a shift from first to second, I get the standard notification that there is an engine malfunction, and goes into limp mode. I have only had this happen to be twice. The first time was last March or so. I simply pull over, restart the car, and everything's fine. Any idea what is going on? It's clearly hard to reproduce, so I do not know how I'd be able to get the dealer to look at it (still under warranty). 2: Also, the engine is getting a bit of a rough idle. It's not nearly as rough as other engines I've used, but it's definitely enough that, per cycle of the engine, there is some variation, which you can hear *very* faintly with the occasional popping sound, which vibrates the stickshift. I am not sure if these problems are related. I sent it to the dealer, and they had the car for about a week, trying to reproduce the idle problem, and they were not able to pinpoint it. I am posting it here because I am considering modifications, but I want to make sure everything is good right now, as mods could surely exacerbate any problems I currently have. The problem is getting the dealer to diagnose whatever is happening. The problems are so few and far between (months), but it's still unnerving knowing that there is *something* wrong. And, whatever it is, again, I would need to reproduce that error to the dealer, or the dealer themselves would need to reproduce it. |
08-30-2012, 04:21 AM | #2 |
161
Rep 7,377
codes?
sounds like injectors or coils or plugs.
08-30-2012, 10:39 AM | #4 |
208
Rep 741
sounds like what happened to my car. I had a CC ID 29 with a P30FE (wastegate stuck)
as enrita said earlier your best bet is to read the codes and replace the coil packs or plugs. If that fails it means your HPFP or injectors are starting to fail. I was unlucky and had to replace plugs, coils, hpfp and all injectors. I think they adjusted my wastegate as well. Car runs perfectly now. Hope that helps. |
08-30-2012, 12:01 PM | #5 |
40
Rep 373
I'm still under warranty, so maybe I can send it to the dealer and they can read the codes. How long will those codes remain in "memory"?
I should make an addendum that I do not know how to check the codes in the car. I just assumed that required an OBD-II cable, which I do not have. |
08-30-2012, 12:12 PM | #6 |
161
Rep 7,377
they remain till you delete them. just take it to the dealer.
09-04-2012, 08:56 PM | #8 |
40
Rep 373
Well, I set up an appointment and had the repairs done. Some sensors got replaced, as well as the front brakes and pads! It was prompt and free. I will check out how my engine idles now.
