How does JB4's map 5 work?
08-29-2012, 08:58 PM | #1 |
60
Rep 1,024
I've heard that map 5 on the JB4 "adapts" to your mods and "learns" what's there. I'm curious if this is actually what it's described as. I just bought all the requisite boltons for my car, and am waiting to have them installed. I have been running map 1 since installing the JB4, since my car is otherwise stock. Once I have my dci, dp's, fmic, chargepipe, and bov installed I assume I'll want to push it up to another map. Do I have to do anything other than set it to map 5? Will it really "learn" what's there and adapt? Will this yield better performance than just using map 2 or something?
I run 93 octane 100% of the time and have no access to higher octane fuels. I also have no real interest in running meth. |
08-29-2012, 09:17 PM | #3 |
69
Rep 868
And meth is awesome
E85 is good It adapts to cooling higher oct = more ponies Nike....... Just Do It
JB4 G5 ISO , AR DP's, DO Meth kit Trunk Mount, ETS 5" Intercooler, M6 Rims, ER Charge Pipe, Fordged DV's, MMp relocated inlets, Ebay 4" chrome Tips, Lux Angel Eyes **********11.910 @ 117.09***1.851 60'********** |
08-29-2012, 09:25 PM | #4 |
60
Rep 1,024
I don't really have anywhere I can go to get it when I run out though. Modding/performance cars are pretty rare around here, and there's no E85 or similar to be had.
08-29-2012, 09:36 PM | #5 |
69
Rep 868
E85 with map 5 I have read same as meth and 93 oct.
I run meth all the time..... Love the power increase When I go to the drag strip I run 100 % meth 50/50 e85/93 and up meth additive to 75 Had some fuel codes..... best was a 12.0 All codes issues sorted out I'll see 11's next specially with cold weather
08-29-2012, 09:54 PM | #6 |
Rainbow Racer
1008
Rep 2,539
IIRC any ethanol content measured due to feedback from LAMBDA sensor's results in adjustments, similar to modern Flex-Fueled Vehicles built after 2006 (according to DOE, a reputable agency), but not as complex, and completely different than using ancient technology such as a Flex-Fuel Sensor to measure ethanol content, like on vehicles built before 2006.
In the JB4 "Open Loop" fueling is auto-adjusted to try to keep A/F close to 12.1 as possible (it tries, it may or may not be perfect. I target, and also hover around 12.1). The reason I quoted "Open Loop" is because our fuel system is typically in a closed-loop mode unless otherwise triggered due to a failure of some parts. IIRC "Open Loop" is really more of upping base fuel pressure a certain percentage, which in effect, apparently increases closed loop fuel pressures. I could be wrong though, so please don't quote me As for auto-adjusting boost, The JB4 basically tries to make sure it's targeted boost doesn't trigger a DME timing correction, as the JB4 can't compensate for "knock" and uses the OEM DME for such tasks. If the knows the DME just retarded timing, boost is reduced to a safe level until you go into "auto-adjust" mode the next time (3-4 gears, WOT after 3,500rpm)
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 Last edited by spool twice; 08-29-2012 at 10:10 PM.. |
08-29-2012, 10:17 PM | #7 |
69
Rep 868
Op knows more than me.... Him = research/knowledge
Me = Beer is good
