4AN Stainless Meth Lines = Aluminum Fittings
08-29-2012, 07:17 PM | #1 |
278
Rep 5,062
Drives: Black e92 335i
So basically every single line I can find comes with aluminum fittings.
Even the stainless steel lines that Devil's Own sells for their meth kits come with aluminum fittings. Should there be a concern with corrosion? I know type 3 hard anodized aluminum is supposed to be able to stand up to corrosion for a long time, but there's really no way to confirm the type of aluminum being used on the fittings. Anybody switch over to brass fittings or just use JIC/SAE fittings instead? I was hoping to buy line with pre-installed fittings, but if that doesn't work out I'll end up just buying my own hose and hoping I can correctly install my own fittings.
JB4 / OSS Angel Eyes / Downpipes / F1-Racewerks FMIC / Custom Meth Kit / BMS DCI / ER Chargepipe / HKS BOV / BMS Meth Elbow / BMW Performance Exhaust / Carbon Fiber Inlay Quad Tips / 19" Miro 111 / Front Aero Lip / M3 Sides / VRS CSL Trunk / Mtech Rear / DD CF Quad Finned Diffuser / LCI Tails / BBK / Smoked Reflectors / F1 Euphoria LED Interior / License LED's / GT 5000k Corners / 5000k HID Fogs / Air Scoops / LED Turn Signals / FK Silverline Coilovers / HPA endlinks / Vibrant Resonators / Osram CBI 5000k D1S
08-29-2012, 07:26 PM | #2 | |
34
Rep 502
http://www.alcoholinjectionsystems.c...c42/index.html FYI about brass and methanol: http://www.ehow.com/info_8762613_eff...nol-brass.html |
08-29-2012, 07:46 PM | #3 | |
278
Rep 5,062
Yeah, I was just too lazy to type out Nickel plated brass, the main point of the post was to find out if anyone has a source for finding the hose I'm looking for pre-assembled. I am looking to use 1/4" diameter braided hose with a stainless covering, but I wanted the hose to come pre-assemled with the fittings on the ends because I'm not sure if I would install them correctly myself. None of the lines I've found come with pre-assembled hose end fittings and the ones that do are usually only for bulk order or they are using aluminum hose end fittings. I just found a couple while typing this though, it will require piecing things together and installing the hose end fittings myself, but I think it's probably the best way to do this.
08-29-2012, 07:55 PM | #4 | |
34
Rep 502
Here you go: http://www.alcoholinjectionsystems.c...duct_info.html |
08-29-2012, 09:45 PM | #5 | |
278
Rep 5,062
Yeah I emailed them about it a couple months ago. The price to get it into Canada was almost triple that of assembling things myself so it didn't work out. Their fittings are also anodized aluminum. I'm going to purchase a leak test kit and just install the hose ends myself, thanks for taking the time to try and help out though.
08-30-2012, 07:30 AM | #7 |
35
Rep 553
I changed all my lines of meth to braided, trust me the diffrrence is huge, no more leaks and the pressure is always there no matter what. Its safe and looks insane!
I have the devils own kit
USED TO HAVE A 385 whp 479 tq N55 335 2011 (AT) AND NOW A 135 M package 2010 (AT) 447whp/504tq
