Datalog inside help please
08-29-2012, 01:38 PM | #1 |
Rep 76
Having an issue where the car struggles between 3200rpm and 4800 rpm boost on my dash shows ok. Between those two rpms I get stumbling power at full throttle and if I let off the throttle the car jerks pretty noticeably. I am running procede with current e85 maps and car was running fine till two days ago. No changes were made to the car. I am new to data logging and need some help diagnosing this issue. Any suggestions such as what channels to log would be greatly appreciated.
08-29-2012, 01:47 PM | #2 |
161
Rep 7,377
just log the std one already setup
08-29-2012, 01:58 PM | #4 |
161
Rep 7,377
just delete the procede folder on your pc and redownload it.
08-29-2012, 02:17 PM | #6 |
161
Rep 7,377
yeah but you might want to research how to use the procede logging etc before actually posting.
08-29-2012, 08:56 PM | #9 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Looks like there may be too much ethanol in the fuel you used in your last fill up. I see this from time to time because e85 is regulated like regular gasoline. Which means it can range from 60% to 90%. Which is why you had no issues for 2 month and all of a sudden, you do now. This is one of the shortcoming of mixing e85 without a flexfuel sensor. You don't always get what you ask for. The best thing you can do is burn off the fuel in your tank and then start fresh. Maybe start with mixing 40% e85/ 60% gasoline and go from there.
