JB4 Z4 with E85?
08-29-2012, 04:21 AM | #2 |
83
Rep 2,132
Drives: FBO+ N54xi
Somebody on N54Tech dyno'd a 2011 z4 35i.....With JB4 and DCI and a 60/40 93/e85 mix and got 386whp | 422wtq...As for not throwing mixture codes, just keep trying from 30% - 50% and just stay with what makes you're car happy and not throw codes.
JB4+usb | P3 Vent Boost Gauge v2 | BMS OCC | BMS DCI | AMS FMIC | AR xi CL DP's | BT Tool | Edibias/NCSExpert/INPA BMW Coding | Cyba Quad Exhaust tips | M-Tech Rear & M3 Front Bumper | Red Cyba Air Scoops | Blacklines | Vinyl Overlays | ACS Roof Spoiler | Matte Black Grilles | LED Side Mirrors | Rear Euro Fogs | etc..
08-29-2012, 06:37 AM | #3 |
Rainbow Racer
1008
Rep 2,539
seems like a low # for an E85 N54 with JB4 tune (some owners are 400+rwhp, but they have DCI)
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
08-29-2012, 08:33 AM | #4 |
79
Rep 2,396
Drives: '08 E90 335i
Not all E85 is created equally It can be as high as 85% Ethanol, but as low as 70%
08-29-2012, 10:11 AM | #5 |
296
Rep 1,515
Drives: Ever changing fleet
No mixing in slowly. Go add 5-6 gallons of E85 and fill up the rest with 93. Drive it around for 10 minutes or so and then swap to map 5. You will need to do a few 3rd gear pulls to allow it to adapt. The JB4 and stock ECU will continue to adapt as you drive it around and go to wide open throttle. As the JB4 tailors the map to your car, you will see the autolearn level number increase in the JB4 software. I would go ahead and fill up now and give the car some time to adapt to the changes in octane. It will be become noticeably stronger over the next couple of days.
23 iX M60, 24 GT3 RS Weissach, 22 Rivian R1T, 23 RS3, 13 E92 M3 Competition: Akra Evo, KW V3, etc
08-29-2012, 10:23 PM | #7 |
Rainbow Racer
1008
Rep 2,539
just leave it in Map 5 and do 2-3 WOT 3rd gear runs 10-15mins after pumping. You only need to go to the other maps (ex. Map 1) if you run out of the E85/pump gas mixture and refill with 91-93octane only.
-Loe P.-
