Ok to replace just one strut? Opinions needed
08-28-2012, 04:50 PM | #1 |
885
Rep 897
Left front is clunking and on its way out at only 33k miles, is it acceptable to replace just one side (and the corresponding mount) or *must* I do the entire front end. Out of warranty, strut is $290 + $100 for mount + labor, cheapskate in me much happier paying $600 than $1200.
08-28-2012, 07:03 PM | #3 |
1561
Rep 4,109
Drives: BMW M3
Agreed, replace both to be economical; you'll have to get an alignment after replacing one or both.
Are you quoting dealership prices?
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
08-28-2012, 09:17 PM | #4 |
146
Rep 1,160
08-29-2012, 06:28 AM | #5 |
885
Rep 897
08-29-2012, 06:59 AM | #6 |
557
Rep 5,367
The only time i'd performed an alignment on any suspension work would include camber kit-changes/springs height adjust/coilovers/geometry related bushings (not swaybar bushings), tie rods, roll center adjusters/subframe bushings. The strut/shocks does not determine vehicle height so caster/toe/camber does not change meaning no alignment is necessary. Unless you removed the set pin/camber located on the mount then camber did not change. This was just common practice at the dealership i worked at.
If youre talking about the rears depending on what bolt(eccentric bolt) you removed to take out the shock then your camber/toe would be off. Being youre at 33k its almost or time to get new tires, i would advise to get the alignment after the new tires. This was just common practice at the dealership i worked at. I dont understand why ppl still think a new or used shock alters vehicle height. If you can push the shock/strut down with little effort using your hands wouldnt you think the vehicle's weight will not do the same?
You can follow my builds on IG: Tee212 |
08-29-2012, 07:28 AM | #7 |
885
Rep 897
I understand the logic being put forth here, although I'm curious as to how much variance there can be between new and a part with 33k on it. Just pisses me off that I am replacing suspension components at this mileage. 33k can't be normal I would think the other should last to 80-100k, what are the odds of both failing early.
All this being said I'm sure i will end up doing both just to be safe, is 2 hours a side a reasonable expectation for labor? |
