Help with some Procede Datalogs
08-28-2012, 04:32 PM | #1 |
200
Rep 2,799
I'm trying to read this correctly but I'm having a hard time making sense of it. I'm getting sort of a stutter in my third gear when I'm trying to maintain full boost. I believe it has something to do with my OL fueling, I just need some help to make sure it is in fact the culprit.
These are the aggressive stage 1 maps with boost turned down from 18 to 16psi, OL set to 80% and wg comp set to 30% on a Rev 2.5 Here is a log of a 2-3pull and here's one of just a third gear pull, where the marker is is where the stutter occurs thoughts?
thanks to MGallop |
08-29-2012, 01:06 AM | #4 |
200
Rep 2,799
I was thinking that was the case, so what I went ahead and did was set it to 100% just to see if there was any difference. Same issue occurs, I hit the ceiling. So tomorrow morning I'm going into FFTEC and having my car flashed with the Procede flash, I'll update this thread tomorrow with news of what is happening.
thanks to MGallop |
08-29-2012, 09:55 AM | #5 |
45
Rep 473
Your timing looks horrible its flat all over the place, it looks to be droping once you reach above 30% on the fuel trims, hopefully the flash helps keep us posted
Cobb JR Tune, HFS-4, DCI, AMS Intercooler, Vishnu CP, Forge DV's, AR DP's, RPI exhaust, AR OCC, BMW STS, Spec stage 3+ clutch, CDV delete, H&R Coil overs, Quaife LSD, DefiV Lock down kit, WOTbox.
-SOLD |
08-29-2012, 11:01 AM | #6 | |
"J" BONE
24
Rep 578
procede v5 rev3, afe dual cone intake, full catless exhaust with muffler delete, hm style carbon fibre lip, 235/35/19,275/30/19 satin black linea corse818, H&R sport springs, Vishnu charge pipe with forged diverter valves, matte black kidneys, mtec superwhite angel eyes and fogs, bms cdv ER fmic, VRSF coated DP. Vishnu pwm meth kit
08-29-2012, 11:44 AM | #7 |
45
Rep 473
30% on your fuel trims the max is 34 when you run to much fuel it drops the timing. Use to happen all the time in my car when I had the procede. Mine would max out the trims the whole time though.
-SOLD |
08-29-2012, 03:19 PM | #8 |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
forgive me if this is a dumb question but are you running 91 octane? If so, then I think you're supposed to run stage 0, no? Not sure if this might affect your fueling. If you're on 93, then never mind!
edit: I also found this post by shiv in a thread where a guy was maxing out his fuel trims for an extended period of time (although it was an E85 mix...). Again, I am not expert here. Just trying to help and learn at the same time. Thread can be found here: http://www.e90post.com/forums/showthread.php?t=736335 "OP- Just drop your boost setting by 10-15%. ~18psi at 4000-4500rpm is too much boost with a 50/50 mix without methanol and/or a ProcedeFlash. If you limit boost a bit, your AFR will fall in line nicely and your trims wont max out." __________________
Cobb E40 PROtune by Jake@PTF/RR catless DPs/aFe DCI/ETS 5" FMIC/ER CP/Forge DVs/Alpina B3 TCU flash/BMW Perf. Exhaust./BMW Performance Style 313s/M-Tech Rear
08-29-2012, 05:31 PM | #9 | |
200
Rep 2,799
thanks to MGallop |
08-29-2012, 05:57 PM | #10 | |
32
Rep 520
KW V3's / AA Stage 2 Supercharger / Catless Mid-pipes / AA Mufflers / Apex Arc-8's / PFC 09's |
08-29-2012, 09:37 PM | #12 |
200
Rep 2,799
Haven't relogged yet, I'll go out tonight and do a few runs, I just adjusted a few settings and from what I feel it's running smooth as butter.
I have shell 91 in the tank, boost set to 17psi, and OL set to 70% right now. I'll report back once I put a log together, but as a preliminary impression, the procede flash has fixed my issue!!
thanks to MGallop Last edited by Dmacc; 08-29-2012 at 10:02 PM.. |
08-30-2012, 08:28 AM | #13 |
45
Rep 473
Curious as well? Post up a log asap.
-SOLD |
