Dinan flashes
08-28-2012, 01:48 PM | #1 |
1003
Rep 3,396
Dinan flashes
So I've had my Dinan flash now for a while and have been pretty happy for the most part. I know it's fairly conservative compared to others available but I wanted something that would compliment my BMW warranty and since I was not looking to go FOB, I though it to be all around less potentially troublesome.
Let me start by saying i am happy with the Dinan tune but I have noticed this flash at times has a couple of personalities. One day it can be a bear but the next day it might be considered even a bit less motivated than stock! I've gone through some threads here and at other BMW site and find that I am not alone with this experience. So why is this tune not "all it can be" everyday of its life? Are other flashes like this? Gas and weather seem to be the biggest factors but then again everyday can't be low humidity and upper 60's. RE; gas, I always use Shell 93 V-Power. So a little helpful insight as to what's going on would be greatly appreciated. PS; Dinan bashes restrain yourselves please, if you can't offer objective no bias comments...don't respond. Thanks. |
08-28-2012, 02:02 PM | #3 |
14
Rep 961
It sounds like you've already figured out one of the main causes: weather. High CATs and high humidity kill these cars. If you don't already have a BT I recommend picking one up and do some data logging to compare the differences in how the timing looks on a hot day and then a cool night. Timing follows a correction table determined by CATs and can be a very significant performance hindrance.
08-28-2012, 02:41 PM | #5 | |
1003
Rep 3,396
08-28-2012, 05:22 PM | #7 | |
14
Rep 961
Just for example, I have logs of a Cobb map where a tune should be seeing ~9 degrees of timing, however the IATs where north of 140F and climbing so it was only getting to ~3 degrees. |
08-28-2012, 05:43 PM | #8 |
nsomneeak
39
Rep 501
I definitely noticed that my Dinan tune seemed inconsistent and, aside from hot days, I'm pretty sure it was the stock FMIC getting heat soaked, as it usually started out strong.
RB Turbos w/ N20 TMAP Sensor | 93 Octane Protune by Cobb Plano | xHP Stage 3 | BMS DCI | STETT CP | Forge DVs | RB PCV | Helix FMIC | CP-E Catted DPs | Walbro 450 | Bilstein B12 | M3 Control Arms | Defiv Lockdown Kit | BBS CH | Michelin A/S 3+ Hixson BMW of Monroe, LA - Shady Dealer | |
08-28-2012, 06:45 PM | #9 |
79
Rep 2,396
Drives: '08 E90 335i
+1 for IATs/Weather Conditions killing your performance. If you can, get an aftermarket FMIC in there. It'll help give you more consistent performance, reduce your IATs & be less susceptible to heatsoak then the OEM core
08-28-2012, 06:51 PM | #10 |
1003
Rep 3,396
Well, looks like an FMIC is in my future. I had noticed they were pretty popular here amount e90 users, now I understand why.
Supporting mods - who knew! Thanks guys. |
08-28-2012, 06:58 PM | #11 |
145
Rep 1,314
Drives: 2021 X3 M40i, 2018 Mustang GT
So are you gonna go All-Dinan here or try other aftermarket intercoolers such as Helix, ETS, etc?
08-29-2012, 08:24 AM | #12 | |
1003
Rep 3,396
For me, Dinan a Spearco based design seems an obvious good starting point to look at. |
