Exhaust Rattle!!!!!
08-28-2012, 12:26 PM | #1 |
15
Rep 294
Exhaust Rattle!!!!!
This rattle is driving me crazy! Every time I go over a bump, or those thick painted lines on the road, my exhaust rattles right underneath the center console.
This happened after I installed my VRSF downpipes, I have currently uninstalled/reinstalled them several times which is BY NO MEANS easy. I absolutely cannot find where they are rattling from, they seemed to be hitting each other so I wedged a large washer in-between them to hold them apart. Still didn't fix the rattle and now I'm stumped Can anyone help me find this rattle? Pics would be GREATLY helpful!
JB4 and other stuff
08-28-2012, 12:51 PM | #2 |
290
Rep 28,154
did you check if the exhaust itself it hitting the chassis brace in the center of the car? sometimes dps can shift the exhaust down lower, resulting in it hitting that brace.
also did you check the front dp isnt hitting the bolts on the motor mount on the engine? and that the back dp isnt hitting the heat shield in any way? some pics of the exhaust by the chassis brace and dps around engine will definitely help narrow down where your rattle is coming from |
08-28-2012, 01:12 PM | #3 |
79
Rep 2,396
Drives: '08 E90 335i
Check the rest of the CBE & did you make sure the V-band clamps/DP Gaskets were properly installed? Also might be the DPs rubbing against each other (vibrating noise when you go over bumps)
08-28-2012, 02:08 PM | #4 | |
I even mod my cereal
246
Rep 3,441
Drives: 11 ZCP DCT M3 14 328d 21 GT4
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser |
08-28-2012, 03:24 PM | #5 |
15
Rep 294
I will do some more investigation on the situation.
I forgot to mention my exhaust is also aftermarket but was not rattling prior to DP's. Also on the stock exhaust there is some kind of clamp thing that I did not transfer over to the new exhaust.
JB4 and other stuff
08-28-2012, 04:18 PM | #6 |
17
Rep 126
after 5 months with the rattle, i finally fixed mine it was pain, but you just need to work through the system until you find the contact point. Loosen the v-clamps, the exhaust at the collectors and the main hanger and then readjust. My front DP was hitting the subframe and finally got it fixed.
2022 M3 Comp XDrive - BSM on Silverstone - CCB - Exec Pack - CF Buckets - CF Ext and Int package - KW HAS Kit - Awaiting Delivery
1993 Porsche RS America - Polar Silver on Black - 229 of 701. Motion Control Coilovers - BBS LMs - 993TT Big Brakes - Roll bar - Recaro Sportster CS's - Golden Rod/Rothsport SSK - Full Race Billy Boat Exhaust - ERP camber kit |
