Please take a look and help... timing drops
08-25-2012, 07:24 PM | #1 |
86
Rep 639
I have been playing around with timing on my car with e85. I noticed when I log timing corrections for each cylinder and actual timing on cylinder 1 I got some strange results tonight... There are no timing corrections, but the acutal timing drops from 9 to 2 to 0 then back to 9 then back down to 0 and stays around there. Car ran really well... up until now I haven't seen timing pulls.
Why is the timing being pulled without anything logged under timing corrections? Here is the data and a graph... |
08-25-2012, 07:54 PM | #2 |
86
Rep 639
I just lowered the timing a degree or so along the middle and ran another log.
Looks much happier now. I guess my question is, it is now running what I am asking almost the same as before... if I was asking for too much why was it dropping the timing by 9 degrees or so if it could handle only 1 degree less... I am lost |
08-26-2012, 06:11 AM | #3 |
86
Rep 639
What's up with the lack of interest lately...
Anyone? |
08-26-2012, 07:10 AM | #4 |
184
Rep 2,841
I don't run Cobb.....but to me it looks like in your first datalog, you had a brief but significant throttle closure.
Your boost and throttle both take a nosedive around 3500 rpms (if I am reading that graph correctly). So some event took place there and timing was probably reacting to this via the DME. So no timing corrections since the DME probably switched to a failsafe timing table when this event happened and targeted the timing curve you see on that graph. So I don't think the issue is with timing......you have to start questioning why you had throttle closure. |
08-26-2012, 07:35 AM | #5 |
86
Rep 639
I think I took my foot off the pedal for a sec... I just assumed timing would get back after a second or so
08-26-2012, 07:39 AM | #6 |
86
Rep 639
i did take my foot off the pedal, but the timing drops .1s before that event... I wonder if its just a problem with the log and the timing drop had to do with my foot... Maybe the whole first log is worthless because I let my foot off for a second
08-26-2012, 09:14 AM | #7 |
161
Rep 7,377
You need to make many logs of 3-4 th gear and see how it looks even when heatsoaking. Basically you need to test a lot with different conditions of temps.
1 log does not tell how the car runs.
