Dyno Results
08-25-2012, 06:11 PM | #1 |
Rep 39
Dyno Results
Went to the dyno today. it was a mustang dyno. Not sure how good the dyno graphs will show up but here they are. AFR's were all over the place, way too high had to abort the run at 5500 rpm's. Is running way too lean!!!
2008 335 stock except DCI and Procede running E85/100 oct 50/50 mix. Baseline with DCI E85/100 oct in tank on map 0 299whp 312tq 401 whp 471 tq |
08-25-2012, 06:42 PM | #2 |
Rep 54
Nice to see CIN....
On the e90, I counted on those guys more times than I can count when I was pushing a G35 around. Bobby and those guys are first class.
Good numbers, what's your plan for the AFR being all over the place? |
08-25-2012, 06:49 PM | #4 |
12
Rep 232
big numbers !!! very nice
what is your max timing 13.000 14.000 ?
2007 335i coupe AT-- I80AS--FBO -stock turbos--COBB v402 beta stage 2 + ATR-- NITTO'S 275-40-17 NT05R --- 12.025 @ 120 mph -- full weight
08-25-2012, 07:02 PM | #6 |
42
Rep 659
your fuel trim is maxed way up, that's why the afr was all over the place. what's your open loop fuel setting?
you also had timing correction. but for e85, i think timing could be more aggressive. what's the inlet air temp? |
08-25-2012, 08:11 PM | #7 |
Rep 39
08-25-2012, 08:27 PM | #8 |
Rep 39
Bobby has been great to deal with. I have a friend with a Nissan so I went down with him today.
08-25-2012, 09:47 PM | #9 |
51
Rep 923
Ok, here is the log scaled correctly so we can better see what is going on. You maxed out your fuel trims for an extended period. This means the DME was not able to add enough fuel to reach your targeted AFR. If you have your OL Fueling set to 100 and you are still maxing your fuel trims, you may need to use a lower concentration of E85 or possible no E85 at all at least until we can figure out whats going on fueling wise on your car. You were running very lean during your peak torque. You are still losing a little power even running race fuel and E85 due to your high IAT. The DME will pull timing to compensate for the high IAT. I think your timing pulls were from IAT compensation and not from knock. It also look like you are having a slight boost oscillation as well but only during the peak boost. It seems to settle afterwards though so it may be nothing. Can you notice it at all on the street? It could be a leaking Diverter Valve under high boost, but that is just a guess and I could be way off.
To get the the AFR to scale correctly, when you have the datalog open click on the AFR Bank 1 channel (the one in the bottom left not the top section) to highlight it. Then press the P button on your keyboard. This will open the properties of that specific channel. From there you can either manually set your max and min values (which I usually do) or you can check Autoscale. After you are finished with AFR Bank 1, follow the same instructions for the other Bank. For your particular log I scaled it to min 12.5 and 19 max. Typically when the AFRs are where they are supposed to be, I use 11 min and 14 max. I like being able to see in more detail the AFR trace. Last edited by jdbretz; 08-25-2012 at 09:53 PM.. |
08-25-2012, 10:07 PM | #11 |
51
Rep 923
I'm not sure that comment quite applies here. I am not bashing flash tunes at all, but I have never seen a flash tune only and DCI produce anywhere near this power level. Cobb Stage 2+ Aggressive is close but doesn't even reach it and you need to be FBO to run that. There is a fueling issue that needs to be sorted out for sure, but the answer is not to switch to a flash tune. I think this can stay civilized and not resort to the typical which tune does this or that better. I do concur that a flash tune, if tuned properly, can handle fueling better, but that is not to say a piggyback cannot do it adequately as has been seen for years now on this platform.
EDIT: It you are referring to the "Procede Flash" I apologize as that may alleviate the issue the OP is facing. I just assumed you were referring to switching to Cobb |
08-25-2012, 10:19 PM | #12 | |
Rep 538
08-25-2012, 10:24 PM | #13 |
51
Rep 923
08-26-2012, 08:20 PM | #14 | |
Rep 39
08-26-2012, 11:14 PM | #16 | |
14
Rep 961
e85 has a very beneficial cooling effect inside the combustion chamber, however the TMAP sensor never sees that so as far as the DME is concerned your IATs are as reported. |
08-26-2012, 11:30 PM | #17 | |
8
Rep 395
When this car is running correct afrs with appropriate advance it would make less but safer power, and is he not FBOs?? 2 cents; Glory runs mean less to me
COBB S2+ - Mr.5 CAI, Catless DP, Catless MP, AMS FMIC. |
08-27-2012, 12:35 AM | #18 | |
Rep 538
08-27-2012, 01:18 AM | #19 | |
68
Rep 1,432
08-27-2012, 02:42 AM | #20 |
161
Rep 7,377
Normally you should make sure the car runs perfectly fine before taking it to the dyno and realize it goes lean.......
08-27-2012, 08:35 AM | #21 | |
14
Rep 961
I would be curious to see where OPs IATs are at the end of a 1-2-3 gear pull. That's a lot of boost and timing for a stock car. |
08-27-2012, 05:16 PM | #22 | |
Rep 39
