M3 Clutch / Drivetrain Compatibility
08-25-2012, 05:08 PM | #1 |
52
Rep 748
Wondering if anyone has looked into whether the M3 clutch was interchangeable with ours. Tried searching, but found nothing. They do however use the same transmission, albeit with a different bell-housing and input shaft possibly.
I read a thread where people were talking about using the M3 rear end in these cars, but IIRC the drive shaft needed to be shortened. Does anyone know if this swap was actually ever performed? Just wondering if any of the beefed-up parts from the M3 swap in outside of suspension.
2008 335I E92, AW, VFF700, 18" Forgestar F14, M3 front/side, M-tech rear, AMS IC, H&R Touring Cup Kit suspension, HID AE, ER Charge Pipe & Synapse BOV, CIC Retrofit, Quafie, DSS, Defiv Lockdown, SPEC 2+/Steel SMFW, Walbro 450
08-25-2012, 05:11 PM | #2 |
161
Rep 7,377
M3 has less torque than n54 so dont see why you would want to use that. Diff has been swapped just search for the thread.
08-25-2012, 05:14 PM | #3 | |
52
Rep 748
I'll see if I can find it... and hopefully get a ballpark in cost. Update: Looks like too much work and room for error... Shortened drive shaft and half shafts. http://www.e90post.com/forums/showth...diff%22&page=7
08-25-2012, 05:37 PM | #4 |
161
Rep 7,377
Question is why do you want to use the m3 one? Is yours slipping? There are many options out done for the n54 so i would look into that instead of focusing on m3 parts that probably wont work out well... If you cant find any info here on that means 99% it cant be done.
08-25-2012, 05:44 PM | #5 |
52
Rep 748
No, but I plan on going single turbo shortly and want to keep stock drivability. Right now I am looking at Spec 2+ with stock FW.
08-25-2012, 06:00 PM | #6 |
161
Rep 7,377
Hpf clutch is another good option.
08-25-2012, 07:04 PM | #7 |
52
Rep 748
Yeah, but I want to be able to launch on slicks without welding the clutch when I get to that point. Plus Spec is about half the cost.
08-25-2012, 11:28 PM | #8 |
307
Rep 5,175
Can anyone confirm if the HPF clutch is just a WAY marked up South Bend feramic clutch? HPF is notorious for rebranding South Bend clutches and slapping their name on it. The SB ferramic is only around 800 if I remember right.
654 RWHP ... ! Vishnu/FFTEC Single Turbo 335
