COBB S1 aggressive ok for stock car
08-25-2012, 04:44 PM | #1 |
48
Rep 609
Does anyone run S1 aggressive with 94 octane gas on a stock 335?
Is that advisable? or too much boost?
2008 E90 335xi sold
2015 SSII M4 current |
08-25-2012, 04:47 PM | #2 |
86
Rep 639
Ummm. Everyone? Not sure why you're worried...
08-25-2012, 04:57 PM | #3 |
161
Rep 7,377
Np , thats for what that map is for...
08-25-2012, 05:54 PM | #4 |
12
Rep 232
nothing to worry about,,
the worst that could happen is missfire
2007 335i coupe AT-- I80AS--FBO -stock turbos--COBB v402 beta stage 2 + ATR-- NITTO'S 275-40-17 NT05R --- 12.025 @ 120 mph -- full weight
08-25-2012, 07:00 PM | #6 |
145
Rep 1,314
Drives: 2021 X3 M40i, 2018 Mustang GT
I'm running it on a stock car. No problem at all. Cars a fuckin beast.
08-25-2012, 07:49 PM | #7 |
48
Rep 609
thanks - appreciate everyone's answer
waiting for S1 aggressive install to be done - fuel pump sounds like its going crazy but i guess thats a normal
2008 E90 335xi sold
08-25-2012, 08:00 PM | #8 |
12
Rep 232
yes it is normal
08-26-2012, 01:38 PM | #10 |
39
Rep 1,154
I run stage 1 aggressive on a stock car. No problems. i didn't realize they still sold 94 in jersey. Why did they stop on the turnpike?
2016 340i xdrive
2009 335i |
08-27-2012, 12:22 AM | #12 |
79
Rep 2,396
Drives: '08 E90 335i
+1 for logging & making sure that the car is running "happy"
Stage 1 Aggressive otherwise is completely fine for a stock car, consider upgrading your filter or DCIs to guarantee you're getting enough air sucked in |
08-27-2012, 06:39 PM | #13 |
48
Rep 609
thanks - i did connect the AP up while driving and just saw a few errors but was just in monitor mode not logging mode
will have to log and and i assume i will be able to connect the AP to the computer to get more info
2008 E90 335xi sold
08-27-2012, 07:49 PM | #14 |
79
Rep 2,396
Data Log the Default Parameters & use Zasquatch's template to graph (http://www.e90post.com/forums/showthread.php?t=665232) the data. Once it's graphed, you can post it up here (or in the official COBB thread) & will get plenty of feedback on whether the log is good or what could look better
08-27-2012, 08:01 PM | #15 | |
48
Rep 609
thanks!
2008 E90 335xi sold
08-27-2012, 08:27 PM | #16 |
50
Rep 1,677
Drives: 14' GMC Terrain SLT-2
For those who are running ACN 91 Fuel, 20% E85 does the trick, for S1 Agg.
check out my logs. All stock with DCI, 60 - 65 deg. Outside Air though. HE-HE Gotta do my logs early in the morning to see decent power. Get heat soak after 2nd pull, ETS IC be here tomorrow, change file extension to cvs.
SOLD:: PTF Pro eTune by Dzenno / COBB S1+ E50 Alpina B3 Flash / ETS FMIC / ER CP / CPE DCI |
08-27-2012, 08:33 PM | #17 |
50
Rep 1,677
see my post above
08-30-2012, 07:58 AM | #18 |
48
Rep 609
how do you interpret a data log such as this
https://docs.google.com/open?id=0B21...VkyQkRLZnZoTHc or graph like this https://docs.google.com/open?id=0B21...m9uUDF4QzFCbk0 any misfire?
2008 E90 335xi sold
2015 SSII M4 current Last edited by SSM46mt; 08-30-2012 at 08:17 AM.. |
08-30-2012, 08:25 AM | #19 | |
50
Rep 1,677
08-30-2012, 08:27 AM | #20 |
161
Rep 7,377
if you have a missfire the engine will throw a cell and you will notice it pretty well. Missfire code will be present as well.
Also when you log do only 3rd gear and a bit of 4th WOT than stop the logging.
08-30-2012, 08:38 AM | #21 | |
48
Rep 609
i am seeing error right on the AP when in monitor mode but not sure how that makes it into the log
2008 E90 335xi sold
08-30-2012, 08:40 AM | #22 | |
161
Rep 7,377
in bold i dont understand. be more specific. Read the codes .
