850W Radiator Fan UPGRADE Finally Installed
08-24-2012, 08:48 PM | #3 |
112
Rep 2,856
Drives: 2011 335is E93
Serious research and input for the community.
Thanks OP! Your work is commendable! |
08-25-2012, 06:42 AM | #5 |
79
Rep 1,617
Great writeup!
I see how the fan will help to cool the car down between sessions at a trackday. However, I don't think it'll help with overheating issues during driving on the track. But maybe I'm wrong and I look forward to your test results!
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
08-25-2012, 09:32 AM | #7 |
79
Rep 1,617
Last weekend, I've driven two 335i's on a trackday in hot summer heat (85°F):
- my own 6AT car equipped with ER Sports OC, AR Design OC in front of the radiator and PPK radiator. - a 6MT car with upgraded OC. Same tune, similar suspension mods, same day, same track. I managed to overheat my car within two hard laps, water temps going above 240° and power completely cut by the ECU. In the 6MT the car could be pushed no problem for a 30 minutes session. So this made it clear for me that the real culprit is the heat exchanger in the radiator: the 3 lowest rows are used by the transmission oil which exchanges the heat with the engine coolant. This is fine when the engine is cold as it helps to get coolant temps up quicker, but on the track it becomes a handicap where the hot tranny oil simply overheats the coolant even more. What we need is an external tranny cooler to keep both circuits separated.
08-25-2012, 11:38 AM | #9 |
161
Rep 7,377
Best would be in front of intercooler IMHO. Shouldnt be that difficult .
08-25-2012, 12:17 PM | #10 | |
164
Rep 2,556
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
08-25-2012, 12:55 PM | #11 |
79
Rep 1,617
I don't think so. Nobody jumped on the wagon due to the high price tag.
08-25-2012, 01:19 PM | #15 | |
79
Rep 1,617
1) Cooler cores are widely avaible. We need a custom bracket to fix it and stainless braided lines to connect to the tranny. And then some block-offs for the connections on the radiator which are no longer uses. 2) either in front of the radiator or of the intercooler or in the driver side wheelwell. 3) therefore installing it in the wheel well is a better option.
08-25-2012, 01:28 PM | #16 | |
164
Rep 2,556
Nice write up btw.
08-25-2012, 03:23 PM | #18 |
422
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
Good stuff! How fitting that your forum name is N54_Fan!
