ABS, DSC, No Cruise Control ....HELPPPPP!
08-22-2012, 08:44 PM | #1 |
49
Rep 770
2007 e92 335i with 49k on the odo..
These warning lights just popped up..hooked up my laptop to the car via JB4 and no codes.. ABS Malfunction DSC Malfunction "Brake" (color red) Also note that my cruise control is malfunctioning and lets me know it is when i try and use it..My blinkers DO turn off after making turns so im thinking steering angle sensor is still good..correct me if im wrong. From reading other post's it could be anything from bad wheels sensors to a dsc unit failure etc. Anyone else experience simliar symptoms and what was your fix, total cost etc.. Thanks so much in advance fellow e90 posters. |
08-22-2012, 08:48 PM | #2 |
29
Rep 968
Drives: 2007 335i Coupe
Either wheel speed sensor or steering angle sensor.
My car had the same issue after I installed my Rougue toe arms in the rear and my car was way out of alignment for a day. We first looked for the steering angle sensor in the Rack and my early build does not have one down there. Then we got the alighnment done and the car was good to go. If your alignment is not way off then it's probably one of the above. |
08-22-2012, 08:52 PM | #3 |
69
Rep 868
I had that awhile back....... Exactly. I think it was called dsc pump or something like that........ My cpo covered it
If u need part #,s I might still the paper work. Pm me tomorrow and I'll look in my "back to the dealer again BMW file" to see if I still have it R Mine is a 2007 coup auto
JB4 G5 ISO , AR DP's, DO Meth kit Trunk Mount, ETS 5" Intercooler, M6 Rims, ER Charge Pipe, Fordged DV's, MMp relocated inlets, Ebay 4" chrome Tips, Lux Angel Eyes **********11.910 @ 117.09***1.851 60'********** |
08-22-2012, 09:21 PM | #4 |
MFCEO
Rep 191
Could be bad wheel speed sensor, bad wheel bearing causing loss of sensor signal, ABS pump (hydro unit), DSC module...
No codes thrown? I think ABS pump is the most costly out of these options ( i think around $400 somthing for part), wheel speed sensor being the cheapest.
08-22-2012, 09:54 PM | #5 |
11
Rep 155
this happened to my e46 M3 and they were able to recalibrate the sensor and the issue went away. Not sure if they can do the same for E92
08-22-2012, 09:59 PM | #6 | |
49
Rep 770
could i need a new battery possibly? i know the car goes nuts when batter is about to die or gets disconnected etc..could be on its original 2007 battery gotta check! |
08-22-2012, 10:03 PM | #7 | |
34
Rep 502
08-26-2012, 08:29 PM | #8 |
49
Rep 770
So..took it to a shop and they said it seems to be my DSC module..all wheel speed sensors are reading normally..voltage is good etc..
He also checked my battery which was good as well.. |
08-26-2012, 08:36 PM | #9 |
219
Rep 3,012
Could be many things but my steering wheel was off by a single notch and it caused a bunch of these problems. Also dying battery makes your car do funny stuff.
