LSD worth it for Street Driving?
08-22-2012, 10:18 AM | #1 |
125
Rep 3,004
Hi I wanted to ask people who have Limited Slip Diffs to see if it's worth doing if you don't really plan to track the car. Do you notice handling gains from a spirited street driving perspective?
2007 E92 6MT SGM: MusicarNW Level 2, Procede Rev 2.5, FFTEC/Vishnu LPFP with Flexfuel Sensor and Flash, M3 Offset V701's, WaveTrac LSD, Michelin PSS, Downpipes, M3 Control Arms, TCKline D/A Suspension, LCI Tail lights, Lux AE's, ER Charge Pipe, DCI's, Mtech Front and Rear, M3 Sideskirts, HPF Stage 1 Clutch
08-22-2012, 10:31 AM | #2 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
Yes.
The i8 needs a V8 amirite?
08-22-2012, 10:32 AM | #3 |
161
Rep 7,377
Always worth it. Best mod ever
08-22-2012, 10:56 AM | #5 |
43
Rep 497
I know im gonna sound stupid but I need to ask. I always thought it was either limited slip or posi traction on cars. And posi traction was the good one. I always thought led was a standard thing in all newer cars. What do we have if we have neither?
08-22-2012, 10:58 AM | #6 |
161
Rep 7,377
Eh? What?
08-22-2012, 11:12 AM | #8 |
164
Rep 2,556
LSD>tune
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
08-22-2012, 11:25 AM | #9 | |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
08-22-2012, 11:27 AM | #10 | |
Power without control is no power at all...
15
Rep 190
Coming from a RWD 80's Corolla, where a race clutch-type LSD costs ~$900, to a BMW, where an clutch-type LSD costs ~$3500, I was quite shocked Still on my list of things to do . . .
2009 335i Coupe 6MT Blk Sapphire / Blk Leather
2007 328i Coupe 6MT Blk Sapphire / Blk Leather *Sold 1985 Toyota Corolla GTS 5MT 1.5-way Slvr / Blk *Sold 1987 Toyota Corolla GTS 5MT KAAZ 2-way Blk / Blk *Sold |
08-22-2012, 01:07 PM | #12 |
79
Rep 2,396
Drives: '08 E90 335i
NO ONE will dispute whether an LSD is worth it, it's a quality mod. The problem is that is basically cost the same for an LSD as it does to go straight to FBO (tune, DPs, FMIC, DCI, maybe even a CP + Meth if you get a good deal)
$3k can be a lot of coin to drop on a single mod, but if you can afford it spend the $$$ |
08-22-2012, 01:14 PM | #13 |
313
Rep 3,262
Now that I have the LSD, the car feels natural and I'm not even sure that all the traction is from the LSD But then I remember having a lot less traction without it. In corners there is a huge difference but how many corners do you take at high speeds in your daily driving routine ? Also, 2nd gear acceleration is much improved. When climbing a twisty hill there is also a huge improvement in traction. Basically I never feel that the car looses traction in the summer.
Still, the difference with the LSD versus OEM diff is not so significant as others suggest, for daily driving. I would only get it after my car would be fully modded power-wise. Don't forget that the C63 AMG doesn't have a LSD either, and it has a lot more power from factory. OP, you could first run some Nitto 555R's (drag radials that can be very well driven on the streets and have a wear rating of 100) or 555R2's (stiffer sidewalls than 555R - suitable for twisty roads) to see if they help with traction.
08-22-2012, 01:28 PM | #14 | |
1538
Rep 1,665
I can't imagine what a FBO car would be like with an open diff and stock tires... probably like a 662 hp Mustang GT500 with 285 width rear tires - kinda pointless. |
08-22-2012, 01:41 PM | #15 |
2095
Rep 43,350
You can get a rear diff for about $1000-$1300 and installation for $7-800 if you're not doing it yourself.
While it's definitely a costly mod, anything below 40mph is going to be useless/dangerous and will cause premature wear on your tires with full bolt ons. |
08-22-2012, 02:00 PM | #16 |
Rep 313
+1, with any type of spirited driving on regular streets, you should really debate how valuable a LSD would be. I would never regret getting one, but I would never push my car that hard on the streets cause I would be too paranoid here in Los Angeles. Too many people focus on power power power, not enough on planting that power, braking, and suspension.
I think if you are anywhere outside of an urban area where you can rip your car thoroughly, you should definitely get an LSD. |
08-22-2012, 02:10 PM | #17 |
need4speed
510
Rep 1,903
Great thread, I was wondering the same thing as OP. Damn LSD's are so expensive though it's hard to choose this mod when you can by several other mods for less $. I am very sick of no traction though and eating up my $1200 tires...
N54
08-22-2012, 02:12 PM | #18 |
Reborn
84
Rep 1,217
With near 500wtq, the car was almost unusable and unsafe with an open diff. It'd get completely sideways even on a 4th gear hwy roll-on.
If you are just at FBO on 93, it prob isn't that big if a deal. |
08-22-2012, 02:21 PM | #19 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
Even a stock car benefits it imo. And even more so with FBO. At "only" 350rwtq I noticed a huge difference. After I went back to stock diff it was horrible, then I switched to Cobb and with 430rwtq (400 at 2500 rpm) it was downright scary.
08-22-2012, 03:35 PM | #20 |
43
Rep 497
I'm happy i finally asked that question. Coming from a family who talked about owning dusters and vans, positraction was like the cool thing. I remember when I was younger I asked what it was also. And my answer was given an example of when a car is stuck in the dirt. Without posi, only one wheel would try to push out the car, but with posi, both wheels would work. So that's where I got the idea that it was both wheels working while lsd was one wheel. And I never really questioned what the difference was until I came on this board. I mean no one talked about lsd's really in the firebird community that I saw.
This is definitely a more educated car community. |
08-22-2012, 03:42 PM | #21 |
79
Rep 1,617
Totally worth it! One of the best mods!
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
08-22-2012, 03:59 PM | #22 |
127
Rep 865
Drives: BMW X3 35i, Porsche Macan S
FBO 335 is really pointless without LSD. If I did my mods again it would be the first thing I'd do. HP Autowerks gave me a great deal and great customer service when I ordered mine.
MOTIV 750 ST | MOTIV PI | 100% E85 | Fuel-it Stage 4 LPFP | MOTIV Boost Box + MHD Protune | Quaife | Öhlins | Brembo | Akrapovic
