PTF Cobb ProTuned; FBO Pump S2+ [w/ Dyno & Logs]
08-22-2012, 08:57 AM | #1 |
102
Rep 1,903
Drives: e92 335i 6MT
Hi guys,
I recently had my car custom tuned by ProTuningFreaks (PTF) and I thought I would share my experience/results. My car is FBO and I have been running Cobb’s latest and greatest aggressive off-the- shelf (OTS) map: S2+FMIC v402. I was curious to know if there was any room for power improvement over these OTS maps running our Petro Canada 94 octane gas. So, I got in touch with Dzenno@PTF to see what could be done. I’m local to him, so we started off with road tuning. The OTS data logs showed my car is running strong with minimal timing corrections: As you can see, the OTS timing is very conservative ranging from 3 up to ~9 degrees @ 6100 RPM (my usual shift point). Dzenno was able to up my timing in the midrange along with some other tweaks to ensure optimum performance consistently and reliably: Two weeks after the road tune, we went to Champion Motors to see what the gains were. We picked up +17 whp/+14 wtq in peak numbers and a max delta of +22whp/+24wtq in the midrange @ 4900RPM! This is without making any load changes, which may yield even better results. We also did a “stock” run at the end - but with all my bolt-ons. I would expect the base numbers to be 15whp/15wtq lower if it was a true stock run: Ambient: 80F, Humidity: 38%, Pressure: 29.69 in-Hg STD: 1.02 I’m pretty happy with the outcome. Doing back to back pulls with the OTS map vs. the ProTuned map, you can feel a big difference in the midrange at the onset of WOT. The car just feels more “eager” to move with the added timing. Overall, I only have good things to say about my pro-tuning experience. I’ve had some follow-up questions and logs that I was curious about and Dzenno has been able to respond back immediately. So, they won’t just hang you out to dry after the protune is complete. I would recommend getting a protune once you have all your bolt-on upgrades in place; I waited until I was FBO and it was the next logical step for me. I’m thinking of getting a custom E85 or meth map for my next protune. Oh, and for those that are wondering, the Dynojet at Champion Motors is fairly conservative. As a reference, Dzenno made 402whp/445wtq on the same dyno with FBO+meth back when he was still on stock turbos. I’d expect peak ~400whp/~440wtq on more optimistic Dynojets (ie. Neetronics for our local guys). Anyway, here are some quick pics from Champion Motors. They’re a legit shop that mainly specializes in Vettes or LSX motors. There were some serious 900+ whp twin turbo Vettes while we were there |
08-22-2012, 09:07 AM | #2 |
161
Rep 7,377
great review!
PTF FTW!
08-22-2012, 09:53 AM | #6 |
161
Rep 7,377
He got banned...
08-22-2012, 10:19 AM | #7 |
9
Rep 260
Looks good.
I noticed that I got more timing drops with Ultra 94 in the fall/spring. This may be correlated with Petro Canada switching to the winter blend. Probably a good idea to log again in the fall.
Stage 123| DCI | ETS FMIC
08-22-2012, 12:02 PM | #9 |
Rep 182
check out bimmerpost, or protuningfreaks.com. $200 for a remote tune, varying prices for tuning locally on a dyno with them in person, etc.
2009 E90 335i - All go, no show
Mr. 5 Intake, VRSF FMIC, Quaife LSD, BMW PS, M3 Bits, RE Toes, ER CP, Forge DV, JB4, PSS |
08-22-2012, 12:14 PM | #10 | |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Shiv |
08-22-2012, 01:23 PM | #11 |
278
Rep 5,062
Drives: Black e92 335i
Good results man! We should get you some Vbox runs in sometime to see how it performs on the street haha.
I had VERY similar results on my friends custom ATR map I helped him out with WOHOO I feel like a t00ner!! I need to pickup a Cobb someday.
JB4 / OSS Angel Eyes / Downpipes / F1-Racewerks FMIC / Custom Meth Kit / BMS DCI / ER Chargepipe / HKS BOV / BMS Meth Elbow / BMW Performance Exhaust / Carbon Fiber Inlay Quad Tips / 19" Miro 111 / Front Aero Lip / M3 Sides / VRS CSL Trunk / Mtech Rear / DD CF Quad Finned Diffuser / LCI Tails / BBK / Smoked Reflectors / F1 Euphoria LED Interior / License LED's / GT 5000k Corners / 5000k HID Fogs / Air Scoops / LED Turn Signals / FK Silverline Coilovers / HPA endlinks / Vibrant Resonators / Osram CBI 5000k D1S
08-22-2012, 01:49 PM | #12 |
34
Rep 783
Said this before Dzenno knows his stuff! Great numbers without going nuts with boost. Looking forward to your E85 testing, where the heck are you getting E85 in Canada? Any plans for meth?
08-22-2012, 01:54 PM | #13 | |
102
Rep 1,903
I believe the car was running ~15.3psi boost @ 5700 RPM in that dyno run. Load was actually left untouched from the OTS maps. At the time, we figured we would leave that for meth or E85 but may revisit it. EDIT: Load was actually a bit less that OTS. But again, saving it for E85 or meth. Last edited by nitehawk; 08-22-2012 at 02:28 PM.. |
08-22-2012, 02:01 PM | #14 |
102
Rep 1,903
Thanks. Yeah, I figure I should invest in a Vbox at some point; it'll also help to see where my driving skills are at
08-22-2012, 02:08 PM | #15 | |
102
Rep 1,903
Haven't tried local but I'll find a way |
08-22-2012, 03:01 PM | #16 |
74
Rep 565
Drives: 11 MW E92 M3
Nice numbers! You have meth as well correct?
I'm not sure if I should protune it now, or later on when I get meth... |
08-22-2012, 03:31 PM | #17 |
79
Rep 2,396
Drives: '08 E90 335i
08-22-2012, 04:44 PM | #18 |
65
Rep 1,708
What’s with the WG dump in the topend… you can see it in the dyno? I’ll never like the maxed torque below 5k rpm… it’s basically only useful for tranny/clutch stress, spinning tires, and impressing riders. Boost at 5500rpms should be increased if anything to keep your usable avg HP higher. Anyway, disagree with the tuning approach which now seems the standard… copying Cobb. How about actually using ATR, then only slightly changing 2 tables. Glad I can’t get negged here… hehe.
OP, log that mapping on the street… 10deg increase in ambient temps, you’ll see timing dance. I'd love to review the csv files if you're willing to post them... it's fun, especially with dynos to compare. EDIT: props on the detailed post and review! Last edited by Joshboody; 08-22-2012 at 04:52 PM.. |
08-22-2012, 05:37 PM | #19 | |
184
Rep 2,841
You are driving all the way to Niagara Hope you are taking about 20 gas cans with you. IF you have room in the trunk can I add mine? |
08-22-2012, 05:57 PM | #20 | |
177
Rep 6,631
E90 LCI N54 6AT
08-22-2012, 05:57 PM | #21 |
74
Rep 565
08-22-2012, 07:37 PM | #22 | |
79
Rep 2,396
I drove all the way to Maryland to have Jake mine person, was the BEST car ride home ever -- Was incredible to drive down with an OTS Map & then drive back with my E85 Map |
Tags |
cobb atp, protune, ptf |
