How to clean under the hood?
07-20-2007, 01:35 PM | #2 |
Smiling politely
165
Rep 7,931
I just wipe it off with a damp rag from time to time. My engine bay isn't the cleanest, but it looks pretty good.
Some people use chemical cleaners. If you go that route, do it on a cold engine. Our engines stay very hot for a long time.
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
07-22-2007, 12:36 AM | #6 |
30
Rep 1,118
Drives: 2009 E89 Z4
+1 on the Simple Green. Hose it down first, BMW does a nice job of keeping all electrical parts covered, including the battery, so this isn't so much of a problem. After it's damp, spray the Simple Green and let it sit for a few minutes. Hose it off again, and then you can dress it up with a variety of products, I use a citrus type spray. Good luck!
Z4 sdrive30i | Deep Sea Blue | Ivory White Nappa Extended Leather | ZSP |
07-22-2007, 06:53 AM | #7 |
7
Rep 219
I asked this question about a month ago and was told it is never good to spray water directly on the engine. I may be paranoid but I don't think I would spray water under there. After each wash, I use a MF that I only use uner the hood to wipe down everything I can reach. I haven't found a problem with a buildup of dirt or dust because I wipe it down every couple days. One thing I have found is that every time I clean it, I end up cleaning areas I missed before.
07-22-2007, 08:46 PM | #8 |
Special Forces - Discretion is superior
31
Rep 1,011
Drives: 335i Coupe Sapphire Black
+2 on sinnets exact routine minus the citrus spray. I then dry everything I can get to. Sometimes I apply 303 to the plastics and rubber.
M3 + trailer hitch = oxymoron
07-22-2007, 08:58 PM | #9 |
29
Rep 957
Drives: 2022 X3 M40i
I use 303 under the hood, but I've only cleaned under the hood once. I don't know how habit forming it will be, since I really don't want to open the hood of my car for anything except adding windshield wiper fluid.
The battery in our cars are really well protected being that they are installed in the trunk. I'd imagine it would take an awful lot of water from the engine compartment to reach the trunk. |
07-22-2007, 11:18 PM | #10 |
30
Rep 1,118
Drives: 2009 E89 Z4
One more thing...after you spray on Simple Green, use a toothbrush of some sort to get into the nooks and crannies of everything, and once it's dried off on it's own a little bit, start the engine and let the rest evaporate with the hood open, or you can use a leaf blower, but no matter what, let the car run after all's said and done.
I've tried it on a '92, with everything exposed, so I can vouch for the fact that your car won't die on you haha. Still, do this at your own risk. Clean engine bays make it easier for mechanics, since they won't have to sludge around in grease and such while working. This was a forum I used to be on for my first car (that's not my car below though), and a clean engine bay can honestly look quite nice. 92 Acura Legend The citrus spray gives it a shine, whereas the Simple Green is just an engine degreaser.
07-23-2007, 08:30 AM | #12 |
323
Rep 1,080
meaning you just pop the hood, point the pressure washer directly and just fire away??
never thought you could just directly spray water on an engine but hrmmm i may have to clean my engine bay...
07-23-2007, 11:17 AM | #13 |
Rep 17
I have used..
Simple Green in the past and does a pretty good job. Just have to make sure it is rinsed well. I little more expensive, but very good, is the P21S Total Auto Wash. Used this on my WRX bay early last year and did a fantastic job. Had areas of some build up and it was able to break it down nicely.
Just rinsed with a light to moderate spray, and did not have to scrub. Wiped down with a cotten rag. Pablo |
07-23-2007, 12:26 PM | #14 |
31
Rep 746
Drives: 2007 328 Coupe Alpine White
07-23-2007, 12:53 PM | #15 |
Rep 112
I am trying to buy simple green. is this the product?
http://consumer.simplegreen.com/cons_prod_pro.php It's called simple green Max? |
07-23-2007, 02:16 PM | #16 |
539
Rep 18,123
Meguiar's sells a product or two:
Current: 2010 Alpine White 335D LCI l 19" BBS LMs l KW V2 Coilovers l BMW Performance Grilles l MSport Front/Rear l Karbonwerke Trunk l F1 Pinnacle Tint 35% Former: E92 Space Grey 335i Latest pics |
