Question for tranny experts - accidentally shift to reverse while moving
08-19-2012, 02:54 AM | #1 |
345
Rep 1,465
okay i have a 6mt 335i and today this is what i did.
I was coming to a complete stop almost but slowed to around 5mph about to make a left turn quickly before the other oncoming car comes. While the car was technically still rolling foward at 5 mph in neutral, i accidentally put to reverse instead of first gear. I slowly released the clutch and the car began to decellerate real fast but I never engaged the gear. i then realized i wasnt in first but was in reverse. it jusr felt like the clutch got slightly burned from trying to engage but couldnt. There was no grinding, knocking, or shock from anything. did i damage the transmission? The car drove fine. The besr way to describe it is like I am on a hill and rolling backwards and in first gear trying to take off going foward. But now reverse the scenario, instead of rolling backwards and in first gear, I am rolling forwards and trying to take off in reverse. Does this damage the transmission in any way? I was really surprised I was allowed to shift to reverse when the car was still moving forward. Thanks |
08-19-2012, 03:07 AM | #2 |
57
Rep 1,038
You didn't damage anything, besides putting a bit more wear on your clutch than usual. But again, this amount of wear is probably smaller than a panicked uphill start does.
The fact that you managed to actually put it in reverse says that the forward speed was completely unremarkable. |
08-19-2012, 03:36 AM | #4 |
345
Rep 1,465
Maybe I don't understand how transmissions work in general. But I want to ask a few questions and hopefully someone can answer this:
This is ONLY for 6 MT manual transmission, not automatics. 1. The flywheel and clutch both move the same direction regardless of going forward or reverse. True or false? 2. So if you are going in reverse, the clutch is still moving the same direction as when you are going forward? 3. The wheels are connected to the driveshafts which are connected to the tranny gears, which are connected to the clutch disc. So in that sense, when the wheels are moving, many of the transmission gears are moving with it? regardless of whether or not the clutch/flywheel is engaged? 4. So is it technically possible, if you roll a car downhill at 80MPH... but just before you started to roll, you put the gear into Reverse, and someone push the car downhill, all while you are holding the clutch pedal down.... Is this still okay? Now, what happens when they tried to slowly let the clutch out? Would the clutch just not engage ever, until the car reversed direction or would the clutch burn up? or would the transmission blow up? 5. I thought that the wheels are hard connected to the motion of the clutch?? So that if you immediately try to reverse direction, the transmission would blow up? 6. I'm still not understanding exactly how when I was moving forward while in reverse, letting the clutch out, the car was decellerating fast yet there was no transmission shock? Is it because the clutch and flywheel were not engaged? If so, I thought these two devices were spinning in the same direction? Unless, they are not spinning the same direction when the car is in reverse? If that is the case, then, someone else inside the transmission must be "slipping" to allow this to occur. Just exactly what else would be "slipping" within the tranmission to allow someone to feather out a reverse gear, while the car is moving forward with no damage? |
08-19-2012, 06:17 AM | #5 |
Rep 51
2: No, the clutch moves in the same direction in forward or reverse GEAR, but the WHEELS change direction. Thus, if you manage to engage reverse gear while moving the WHEELS forward, the clutch plate will spin in the opposite direction of the flywheel and pressure plate.
If you disengage the clutch while moving forward in reverse gear, there is nothing to slip in the drivetrain besides the clutch itself, which is why a previous poster said you will have increased the wear on the clutch plate. |
08-19-2012, 07:20 AM | #6 |
200
Rep 1,834
Drives: '05 E90 330i Manual
At this low-ish speed nothing really to worry about, and the fact that there was no real crunch sound from the gearbox means that the syncros were able to cope as such. Clutch from such a brief moment should really not have taken too much of a pounding, as said, not more than a hasty pull off on a steep hill. At least reverse is situated on that side of the gate instead on where you could potentially being hauling along in 6'th!
08-19-2012, 08:37 AM | #8 | |
1674
Rep 6,592
I am thinking that you actually did put it into the first and it was the engine braking effect you felt... |
08-19-2012, 08:47 AM | #9 |
93
Rep 1,509
When I was 5, I always wondered what happened if you shifted a car in reverse at 70 mph
2009 E90 328i Monaco Blue
premium/idrive/convience/logic-7/cold weather/ xenons/ saddle brown interior |
08-19-2012, 09:53 AM | #11 |
70
Rep 276
I managed to do that on my 30000GT VR-4 6spd. I meant to go into 6th but instead hit reverse very very briefly and I decent feedback from the shifter like it was going to grind and I realized it was about to shift to reverse at 70mph.
I'd say you're fine. I'm not sure about BMW MTXs, but I didn't think there was any synchronizer for reverse so it would be nearly impossible to actually engage it at any speed above 3-5 mph.
'16 BMW M3
'16 BMW X5M '23 X3 M40i (On Order) '21 Civic Type R |
08-19-2012, 12:01 PM | #13 | ||||||||||
57
Rep 1,038
Clutch. At your speed the tires probably didn't slip. That leaves the clutch. Last edited by AndreyT; 08-19-2012 at 12:55 PM.. |
08-19-2012, 01:26 PM | #15 |
345
Rep 1,465
Thanks guys, I think from what I'm hearing now, in my scenario, both the flywheel and clutch disc were spinning at opposite directions at that moment in time. Since I had the reverse gear engaged, but car was moving forward, the clutch now wants to spin the opposite direction of the flywheel.
I am pretty positive, I went into reverse based on when I removed the gear out and because like I said, I was able to get into gear (which I thought was 1st), slide out the clutch and gave it some gas, but the car wouldn't move, just decellerated even more and felt like I was trying to take off on a steep hill. BTW, I still have CDV - guess I'll keep it in there for mistakes like this! So I take it that in the following situations, the clutch and flywheel spin the opposite direction for a brief moment in time, which increases wear: 1. Rolling backwards on hill, in first gear, trying to take off going forward 2. Rolling forwards on hill, in reverse gear, trying to take off going backwards Really? I don't think so, there are some cases where I'm in such a low speed in the parking lot that if I use 2nd, the RPM would be so low I'd nearly stall. Even though the car is still rolling. |
08-19-2012, 03:30 PM | #16 |
200
Rep 1,834
Technically not suppose to gear down to 1st while driving, for instance if you are about to take a sharp low speed turn going from 3rd to 2nd - not suppose to drop down to 1st in the same manner. But in the case of driving in a parking area for instance and you find that the speed is a bit too low (especially if on an incline), then slow down and gently change to 1st, and then stay in 1st until you know that your car's speed is going to be higher enough for a higher gear. Basically anything faster than walking pace is not ideal speeds for dropping to 1st gear...
