problems
08-16-2012, 08:01 AM | #1 |
184
Rep 2,320
problems
Hey
Would like to get some help my car started shake got half engine light no power working like subaru, no codes, stopped engine start/stoo button and half enginw light gone. Then again accelarated with second gear boom again half engine and no power drove without procede (turned off) drove using 5th gear 100 km and rpm 2500 to france bmw center. They say it can be ecu problem. Can it belike this? Is it fault of bms filters tht not cleaned or ic pipe disconnected any clue?
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
08-16-2012, 08:03 AM | #2 |
161
Rep 7,377
u should turn CAN clear off so the codes do not get erased. Feels like missfires or fuel pump?
08-16-2012, 08:09 AM | #3 |
184
Rep 2,320
But I am using mode 0 on procede so I drive on stock mode so as understand when map 0 activated procede is off?
sometime ago I got this http://www.e90post.com/forums/showth...9#post11036669 from that post I posted I drive map 0 always P.s BMW checked hpfp and injectors they say it's fine. Can it be that pipe from ic poped out?
08-16-2012, 08:22 AM | #4 |
161
Rep 7,377
no the procede is always on..
what you have to do is recreate the situation , read the codes and post them. Than search here for them. Could be fuel pressure sensor, LPFP etc. Than remove the procede and take it to BMW to fix it with the codes still stored in the ECU.
08-16-2012, 09:27 AM | #5 |
79
Rep 2,396
Drives: '08 E90 335i
Need codes to diagnose
08-16-2012, 09:30 AM | #6 |
184
Rep 2,320
Which procede interface I can use to disable can clear from here http://procedetuning.com/BMW/n54/dow...downloads.html I bought procede in 2010
Thanks P.s so if can clear disabled BMW can see codes and fix car?
08-16-2012, 09:34 AM | #7 | |
161
Rep 7,377
08-16-2012, 09:39 AM | #8 |
184
Rep 2,320
I use v5 and I used procede user
interface v5.2
08-16-2012, 12:17 PM | #9 |
51
Rep 923
Open your Procede Software. Connect to your Procede in the car. Go to User Maps, then User Adjustable Parameters. Once that opens, change the option next to CANClear from 1 to 0. Click Apply, then ok. After that go out and drive to reproduce the problem. Once it occurs again, you should have codes stored that you can view. Keep in mind if you drive for a while with CANClear off you will get a Service Engine Soon light because you have Catless DP's. That is normal and not that code you need.
08-16-2012, 12:56 PM | #11 |
184
Rep 2,320
Okay looks like somehow BMW sa manage to read codes I don't know what they did but check codes below they say gona change fuel pump comment please
P.s can somebody link me to procede user imterface that i need to have thanks guys for support http://imageshack.us/photo/photo/688...816174344.jpg/
08-16-2012, 02:36 PM | #12 |
51
Rep 923
You have a misfire in Cylinder 2 and 5. How old are your spark plugs? If after they replace the fuel pump, you still have problems here are a couple things you can try:
Often replacing your spark plugs will fix misfires. Also, you can swap the coils from those 2 cylinders to other cylinders and see if the misfire moves with the coil. If it does, your coil is bad and you can buy 2 new coils. It could also be a leaky injector, but I would try new spark plugs first as they are the cheapest fix, and will usually take care of the problem. The version of the Procede software you already have will work, or you can download the latest one (5.34). |
08-16-2012, 02:49 PM | #13 | |
55
Rep 495
GIAC stage II|AA DP|AA Charge pipe and BOV|AFE S2 Intake|HELIX FMIC
08-16-2012, 03:05 PM | #14 |
184
Rep 2,320
Hope Bmw will fix my car any ideas how much hpfp cost?
08-16-2012, 03:25 PM | #15 |
55
Rep 495
you are out of warranty!!! You need to find a good Independent mechanic.
No clue how much things go for in Europe. HPFP in the USA are covered for 10 years 100k miles or ~ 170,000 kilo meters. Good luck, I hope it works out.
08-16-2012, 03:58 PM | #16 |
184
Rep 2,320
My car has only 30k on a clock km so sad that such things happening...tune I have only 1 year....hope my car will be fixed, thanks guys for great support
08-29-2012, 06:05 AM | #17 |
184
Rep 2,320
***update***bmw sa change hpfp
after it i get this service red: but it seems out of date any clue? ********************************* also after they changed hpfp my bms filters position they changed and forge dvs one pipe was moved to other position can it be left like this? Thanks for support.... later gona post hpfp part number hope it wont die soon........
08-31-2012, 12:16 PM | #18 |
184
Rep 2,320
anybody?
08-31-2012, 12:24 PM | #19 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
The position of the bypass valve and intake filter are of no real significance. But it's a good thing that you got a new HPFP. The new version is made by a different manufacturer and is said to be mechanically sound.
09-02-2012, 02:09 PM | #20 |
184
Rep 2,320
shiv so i can keep that position of filters and forge dvs?
09-02-2012, 02:16 PM | #21 |
195
Rep 6,136
09-09-2012, 02:27 PM | #22 |
184
Rep 2,320
thanks guys how you think my bms filters can be used or i need to clean it now?
p.s about k&n cleaning kit any ideas how long it expire i bought it 2 years ago....
