Hard Water
08-14-2012, 08:45 AM | #1 |
335i, red, sport
Rep 14
Hard Water
I have hard water spots on the drivers side of my car from a in ground sprinkler system. I have washed my car but can't remove the spots from my car and glass. What would work best to clean the hard water spots off and not damage my car?
08-14-2012, 08:49 AM | #2 |
93
Rep 1,509
I get these every once in a while. There are products that can remove them, but I usually just take some clay to them or wait till I polish the car
2009 E90 328i Monaco Blue
premium/idrive/convience/logic-7/cold weather/ xenons/ saddle brown interior |
08-14-2012, 01:55 PM | #3 |
Rep 14
You could use some wax but it will take a lot of elbow grease to get them out. I used some cleaner wax and a porter cable car buffer and mine came out pretty good but afterwards, I had swirls which I had to remove also.
08-14-2012, 03:26 PM | #4 |
18028
Rep 9,378
WHITE vinegar, usually mixed about 50/50 with water. Spray on, let sit a bit, wipe off. You should probably apply your favorite wax/sealant afterwards.
08-14-2012, 11:16 PM | #6 |
93
Rep 1,509
Yeah, clay takes it out of glass and some of the spots on the paint, but after that out comes the polish
08-15-2012, 02:01 PM | #7 |
uʍop ǝpısdn
Rep 63
Drives: '11 335d, SG/Saddle, ZSP, ZPP
I add a couple spoonfuls of borax to my wash bucket each time, it helps soften the water. Just have to make sure it dissolves well so you don't get any clumps. I like to use HOT water out of the sink, add the borax, and let it sit for a few minutes to dissolve.
Ninja edit: This won't get the current spots off the car, but will help eliminate the problem in the future |
08-16-2012, 03:41 AM | #8 |
11
Rep 770
Removing ‘Water spots’
Always start by using the least abrasive product first 1. Use a paint surface cleaner (Z-PC Fusion Dual Action Paint Cleaner or Duragloss 501) 2. Try to dissolve the alkaline-based, surface/etched mineral water deposits with one or more of the following; a) Use a 2:1 or stronger solution of distilled water/distilled white vinegar (Acetic acid) b) Try a 2:1 solution of distilled water/Isopropyl Alcohol (adjust ratio as required) c) Or equal parts distilled water/distilled white vinegar/Isopropyl alcohol. 3. Clean the effected surface with Klasse All-In-One or Zaino Z-PC Fusion Dual Action Paint Cleaner 4. Use detailing clay to remove any `hard' surface granules 5. Use a machine polish (Optimum Polish, Optimum Compound) and a cutting (LC White, Orange or Yellow) foam pad (speed # 4- 5.0) to level the paint surface 6. Use the least aggressive polish/foam pad first, if this doesn’t remove the problem step-up to a more aggressive polish / foam pad set-up 7. Wet-sand with 2000, 2500 or 3000 grit finishing paper “Removing Water (Spots) Marks” - http://www.autopia.org/forum/guide-d...ml#post1448627 |
08-17-2012, 07:38 PM | #9 | |
38
Rep 715
