08-13-2012, 04:40 PM | #1 |
Rep 49
Bluetooth Problems During Calls
I'm suffering from a little bit of a problem with my bluetooth for phone calls. Not sure it its with my phone or with the car.
Every time I get in the car my smartphone (Motorola Droid 3 running Android 2.3) automatically connects and I can make and receive calls. However, if I'm on a long phone call (~5 minutes+), the call eventually "drops", or more like the car just got disconnected from the phone as the call is still active if I pick up the handset. One time that this happened I rebooted the phone, but it didn't reconnect with the car. I had to restart the car and then it reconnected. Has anyone seen anything like this? I guess I need to take it in for service? |
08-18-2012, 11:20 AM | #3 |
288
Rep 1,892
Have you tried updating the Bluetooth firmware in the car?
http://www.bmw.com/com/en/owners/nav...gion=&country= You can do it yourself. |
08-18-2012, 08:28 PM | #4 | |
Rep 30
2012 F30 328i Sport Line 6MT. Timeline
08-19-2012, 09:49 PM | #5 |
Rep 49
Thanks for the tip. I just installed the software update; I'll report back how it goes, but I'm not too optimistic. I read through the release notes and the smartphone compatibility fixes did not seem to mention anything related to the problem I'm describing. Any official way of reporting a problem like this, other than going through the dealer?
08-19-2012, 09:50 PM | #6 |
Rep 49
I'll add that like the other person reporting the same issue, I also have a F30 328i without the Enhanced Bluetooth. I've had this phone for over a year and never had issues connecting with my bluetooth headset.
08-19-2012, 10:19 PM | #7 | |
Rep 49
Reading through bmwusa.com's Bluetooth Compatibility page I found a note saying:
08-25-2012, 09:59 PM | #9 |
Rep 49
Well... I am most unhappy to report that my problem has not been solved by the software update. I guess I'll need to take the car in for service, but I'm afraid of not being able to reproduce the problem when I'm there. I also don't see too many other people reporting similar problems, so I'm not sure if the problem may be with my phone instead.
I'll post if I find a solution. |
08-26-2012, 07:53 AM | #10 |
22
Rep 291
I have an iPhone and no problems, maybe the car wants you to change to the apple team; much nicer phone than an android and you"ll never look back once you join the team
09-04-2012, 02:43 PM | #12 |
Rep 16
I seem to have this problem also. The car disconnects from the phone periodically, whether I'm on the phone or not. I notice it most usually when I am displaying the Messages in BMW Office function - the screen moves from my list of emails/texts to "No Messages" for a few minutes, then refreshes on its own. I also missed a call during one of these periods so it doesn't seem to be only in the Office function.
J |
09-04-2012, 09:52 PM | #13 |
89
Rep 710
I've got a Blackberry and no issues with mine. Don't have enhanced Bluetooth. My wife's Droid3 always drops calls, can't connect, or can't answer a call with Bluetooth enabled on the Verizon-provided Bluetooth earbud. May be a Droid issue, not a car issue.
2018 Mustang GT | Royal Crimson | Black Leather | 6-speed | Cold Weather | Premium Pkg | 20" Alloy Wheels | Tuned to 510HP | Less than $45K
Previous loves: 2015 F30 335i / 2013 F30 335i / 2009 E90 335i / 2007 E90 328xi |
09-04-2012, 10:16 PM | #14 |
470
Rep 1,659
Drives: 2022 WRX World Rally Blue
It may be something to do with the phone as others have suggested. I have a Motorola Atrix 4G and haven't had any problems.
09-12-2012, 03:19 PM | #15 |
Rep 49
I'll say that I have narrowed this down on my side to indeed be a phone issue, nothing apparently wrong with the car (Flashed a new ROM, Maverick 4.5 for any other Droid 3 users, and the problem has disappeared).
08-03-2014, 02:11 AM | #16 |
Rep 2
Bluetooth
I've the same problem on my F11 . You can try to disable access to address book and calls list. The problem seems to be related to the capacity to handle voice and data for simultaneous
08-03-2014, 02:27 AM | #17 |
303
Rep 1,738
I have a Nexus 5 and have used an S4 and HTC One with no problems like this whatsoever. Gingerbread and Droid 3 are ancient in Android years, sadly. There were Bluetooth issues back then too.
Honestly, the dealer won't know how to do anything except try updating the iDrive software. And if you've already done that I would'nt get my hopes up. |
08-04-2014, 10:11 AM | #18 |
21
Rep 126
Drives: '17 M4 Conv Comp, '01M Rdster
Same problem on my 2013 335ix and Moto X. I have narrowed it down to my address book size may be to large and is causing he system to go into an endless loop. With the phonebook sync disabled it seems to be behaving normal
08-04-2014, 01:43 PM | #19 |
23
Rep 204
What cell phone carrier do you use?
I have this problem when my verizon phone is also trying to perform data functions while I make a call. Verizon does not allow simultaneous use of data and voice phone, so if you make call it suspends data use during the call. However, if you using iDrive or other apps that take advantage of data use from your phone when you make a call, it seems to make the voice call flaky. I get static and frequent call drops when I am using my phone as a hot spot for Connected drive apps or when using Waze or Escort's (Radar) app.
08-04-2014, 01:45 PM | #20 |
21
Rep 126
Are you using an iPhone? Android phones support simultaneous voice and data. This has never caused a problem for me before. Just fyi..
08-04-2014, 09:01 PM | #21 |
Rep 49
Seems like this issue never got resolved for some people. I have long since upgraded to a Samsung Galaxy S4, and now more recently to an iPhone 5, and Bluetooth works flawlessly. The Droid3 worked well with other Bluetooth devices, just not my BMW. I even tried custom ROMs on that phone, with disappointing results.
Replacing your phone for something more mainstream might be the only solution at the moment. |
08-06-2014, 01:08 PM | #22 |
150
Rep 233
This is a known issue with certain phones and there isn't really a magic bullet fix for it. There are just so many different phones out there running different operating systems with different Bluetooth hardware that it's impossible for all of them to work flawlessly.
The only sure-fire way of making sure you have a phone that works is by checking bmwusa.com/bluetooth to see if your phone is on that list. If it is and you're having problems, and your car and the phone are running the most recent software, then it might be a car issue. The vast majority of the time an issue like this crops up, it's either due to the phone not having the most recent software update or the phone just not being entirely compatable with the car. I have seen very very few Bluetooth issues relating to iPhones and Blackberries. Most of the ones I see are from non-major Android-based devices. |
