ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Navigation, Audio, Bluetooth, Stereo, Electronics Talk
  TireRack
      07-18-2007, 03:15 PM   #1
Waldorf
Black Opps field agent
Waldorf's Avatar
35
Drives: 135i M
Z4 premium sound has NASTY DSP latency.
I finally found what was pissing me off with the premium sound system in my brand new M Coupe.
the system relies on a multi-channel DSP that takes on crossover duties and the rears (or just the subs) have over 20ms output latency.
the result are awful, muddy lows and subs that makes it sound like blown speakers. the only way to counter this effect is to blast it so loud that the rears take over and the bass from the front is not competing anymore.
this means that i can never put any background music. it's unbearable.
some aftermarket head units have latency correction functionality, does anyone know of any standalone correction units that i could simply put inline to keep the oem components?
my only other resort would be to ditch the oem amplifier for a high quality multichannel unit with some active crossovers and rewire all the speakers using only a stereo pair for input signal into the amplifier.
i can't believe BMW signed off on such a ridiculous flaw.
:rocks: Montreal to Vermont OktoberFast cruise. :rocks:
http://www.e90post.com/forums/showthread.php?t=79557
      07-20-2007, 01:23 AM   #2
chaforjohn
10
Drives: 2006 Black M Coupe
You can use a JL cleansweep, RF Sixty, or Alpine...
      07-20-2007, 02:15 AM   #3
Waldorf
Waldorf's Avatar
35
Drives: 135i M
thanks, i'll look into that
      07-20-2007, 07:00 AM   #4
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
65
Drives: 2006 Z4MC Interlagos
I can't hear the stereo over the exhaust anyway
2006 Z4MC - #LL93158
SS Race Cans, RE X Pipe, DKF Sec 1, Fabspeed Headers, OE STB, AS Shifter, Dave Z CDV, GC Coil Overs, Stoptech lines, Hawk DTC Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, Poly FCAB & RTAB, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM
      08-13-2007, 01:10 PM   #5
Waldorf
Waldorf's Avatar
35
Drives: 135i M
really? i can still kill the Eisenmann with the stock radio.
which brings me back to the topic at hand.
I discovered that, when you crank the sound to an unbearable volume, the bass from the back overpowers the front and the delay is less apparent. it's still not a solution for bad design.
that being said. it's a sports car so i'll forget about that.
      08-21-2007, 11:30 PM   #6
chaforjohn
10
I just wanted to say that I recently replaced the sound system in my m coupe - and it was by far one of the most time consuming projects i've undertaken. I'm a fairly experienced audio nut, and it took about 12 hours total (for a first time) to install:
figuring how to disassemble the car's panels
new headunit,
new 3 way components up front,
amp,
sub,
remove factory amp,
determine stock wiring locations using a AA battery (for test tones)
putting everything back together!
The audio is beautiful now, but I don't think i'd do it again.
      08-22-2007, 09:42 AM   #7
Waldorf
Waldorf's Avatar
35
Drives: 135i M
so, did you keep all of the original wiring?
      08-30-2007, 04:14 PM   #8
BimmerZealot
61
Drives: 2019 BMW X3 xDrive30i
The funny thing is if you read the manual and such they have all this documentation about them working closely with THX and it being the first car certified by THX technicians to have like wonderful sound. Quite frankly the DSP imo is useless it's always off i have yet to use it for longer then 5 seconds. I dont understand how they can call three DSP settings: concert, jazz, church "premium sound" the church DSP merely causes a lot of echo and apparently thats "better sound"? It's a bunch of crap to me, I'll take the standard one any day, besides now my icelink will be 90$ more. Wonderful
      09-07-2007, 12:52 AM   #9
chaforjohn
10
yeah, unfortunately I kept the stock wiring in - they were a decent gauge, like 14 or 16, the music sounds great, so no complaints here...
      09-07-2007, 07:45 AM   #10
Waldorf
Waldorf's Avatar
35
Drives: 135i M
Do you think that I could replace the original amplifier with a 4ch to drive the whole thing?
If not, then one 2ch for bass and one 4ch for the front.
i still have some Alpine V12 amps laying around.
      09-08-2007, 02:22 AM   #11
chaforjohn
10
I'm using a 4 channel now to power my system, but I did unhook the woofers and 4" behind the seats...
150 x 2 front, 400 x 1 (bridged) rear for sub
I say if you have a great front stage, go with the single 4 ch setup, bridge rear. If you want to use all speakers, then get a 4ch and 2 ch.
Your V12 amps should be great - only concern is the V12 4ch, might not be enough power for the 3 way components...
      09-10-2007, 02:03 AM   #12
ricerx1
64
Drives: 2016 M4
Yea you can thats what I did.
I used 2ch to drive my front which i changed to a 3 way focal utopia set up. And the remaining 2ch to drive jl 6w0 subs.
disabled the rear 4" rear fill speakers.
Retained the stock headunit steering wheel controls and bluetooth.
It sounds much better.
And you cant tell once the carpet is back in, that is till you turn the radio on.
      10-01-2007, 06:38 PM   #13
Waldorf
Waldorf's Avatar
35
Drives: 135i M
look like i'll be doing this soon.
did you take note of the color coding used for the wires to the rear?
      10-01-2007, 06:56 PM   #14
ricerx1
64
Drives: 2016 M4
Nope but it was pretty easy to tell. I used a AA 1.5 volt battery. All the speaker wires are twisted pair. Just cut and tap the ends to the battery and note which speakers make a popping noise. The thicker ones goes to the subs and the front kick panel speakers. and theres 1 pair of black ones thats the audio out from the bluetooth.
      10-01-2007, 07:01 PM   #15
155MPH
155MPH's Avatar
Drives: E89 Z4 sDrive28i M Performance
DSP in mine sounds like crap. I leave it off. But without it the sound is fine for me. I am half deaf anyway.
      10-11-2007, 07:38 PM   #16
unionjack
Conceited Prick
unionjack's Avatar
14
Drives: Z4 M Coupe previously
2007 Z4 M Coupe  [0.00]
DSP is junk, no doubt.
previously
AW/IR | Premium Package | Heated Seats | Navigation | Valentine One | Shorty Antenna | Black Kidney Surrounds
zpost
